Id defiantly try to wash that thing out with diesel to get it out. The last three clutch jobs I did on Hondas I just used a impact to get the nut off and no clutch holder was needed if you have some one there to hold the basket or stick a screw driver between the gears but then again a clutch holder is like 20 bucks or you can make one out of flat metal.. Now you will need a large 3 jaw puller to get the centrifugal clutch off if its like a big red/foreman/rancher as its a tight fit. But if want to tear it apart it would hurt to put a fresh set of rings on it and lap the valves.
1984 yamaha 200k
1985 honda 70...some times swap the 125 lifan for fun
1984 honda 200es
1985 honda 200x
atvs:
2013 Honda Rancher 420 ES
