Hey there i have a 1982 atc200, 10.25:1 high compression piston with a 185 top end, everything else stock. So basically with a fresh plug this machine runs and drives great, doesn't smoke, great power, but if you leave it for a while (ex. overnight) and go to start it the plug gets wet and doesn't spark properly. With a fresh plug it starts first pull. I'm running a dr8es-l. The plug when pulled is black and has black resin on it. Ive swapped carbs, cleaned air filter, checked exhaust, moved needle clip but im lost on what this could be, if the motor is still hot it will start fine and run forever. Thanks to anyone that replies.
