Originally Posted by
joe83hd
The starter has made in twian on it. It sounds like it is turning over good. I have put a small amount of gas in the plug hole then put the plug back in and tried the electric start with no luck. I have also givin it a small shot of starting fluid while i crank it with the electric starter with no luck. i have taken my hand and held it over the back of the carb checking for suction while cranking with the starter and it has suction and i get a hand full of gas. I have a old mechanical tach that i plan on check the cranking rpm with. The battery is new, and i have buy passed the battery with a 950 amp jump box straight to the starter with no change still cranks the same and won't start. I'll check the compression but i'm sure it will come out good the gentalmen that owns this ask me to do a top end rebuild because of this starting probelm and the compression was low, so i have bored it first over sized, laped the valves in check all clearances and still have the starting problem. I wish i could leave it as kick only but i don't thank the older gentalmen that owns it can kick it.
