Results 1 to 12 of 12
Thread: Are Progressive Fork Springs Worth the Money?
    Sep 2011
    New Castle, PA
    1,134
    I'm looking at a pair of progressive suspension springs for my 83 212x, http://www.progressivesuspension.com...32&modelID=299
    They are $92.50
    And what is the Wire, Winder, and washers kit? Should;d I get that too? $20
    I'm looking for feedback, goods, bads, what I will notice while I'm riding, etc.
    PS If it matters I'm running a 23" front tire, everything else on the front end stock.
    But this is going to be a TT bike so I'm thinking that these will be a nice upgrade.
    Gone:
    Oct 2013
    Wherever I May Roam
    3,757
    Can't find the 200x springs with that link....am I missing something? I'd like to see them for sure...I might buy some too
    Sep 2011
    New Castle, PA
    1,134
    Heres a fixed link
    No pictures, but there is a bit of a description
    Gone:
    Oct 2013
    Wherever I May Roam
    3,757
    So is that a link to a spring that has a recommended rider weight or is there just one spring rate for the 200x?
    Sep 2011
    New Castle, PA
    1,134
    Just one. Those are the only springs listed on their website
    Gone:
    Sep 2011
    New Castle, PA
    1,134
    Here they are on amazon cheaper (and image)
    http://www.amazon.com/Progressive-Su.../dp/B001J0GAIG
    Gone:
    Slidell, LA
    4,738
    I have them both in my x and my r. I also us 20wt belray for extra cushion. Worth every penny.
    Sep 2011
    New Castle, PA
    1,134
    Thats what I was looking for. Thanks a bunch brendon!
    Gone:
    Jan 2013
    minnesota
    5,911
    Hello DohcBikes;
    I would not recommend a progressive rate fork spring for rough terrain. They will work well for smooth track.
    You can get custom made springs for almost ANY vehicle from my friends at EIBACH but don't tell anyone this. They can also determine the rate of your existing springs.
    http://eibach.com/america/en/powersport/products/atv
    ATV spring tech line.
    1-951-256-8300 x 134
    Jan 2013
    minnesota
    5,911
    POST CORRECTION
    I think the progressive springs in question ARE good springs and work well over most terrains including rough terrain. What i meant to say is that there are other options avail that can cater more specifically to ones weight, bike weight, riding style etc.
    A spring of a specific rate obviously will NOT work the same for a 160 lb rider as it will for a 250 lb rider so the progressive springs mentioned are not a cure all for all suspension ailments.
    O.C., Oregon
    921
    Yes, they made a vast improvement in my 250r suspension.
    1978 ATC70 w/ Piranha 140cc
    2017 YZ 250x- Braap
    Billy Golightly's Avatar
    Live Oak, FL
    15,068
    They are, but you have A LOT of variables to consider.
    You might read this post I made a few years ago for more information;
    http://www.3wheelerworld.com/showthr...796#post934796
    And also this one;
    http://www.3wheelerworld.com/showthr...802#post934802
