definitely a too lean or too rich issue. you say you replaced the carb, I am just guessing with a ebay Chinese knock off. they work fine but are never jetted properly out of the box. check main jet # on old carb and new. swap if necessary.
easy way to figure out rich or lean. remove air box cover. if it runs better carb jet too rich. if no difference leave lid off and give it a shot of ether (starting fluid). if that makes a difference it is too lean
also take notice of needle on carb slide and of old and new. you have to remove both from slide and see which notch the e clip is on. make sure they are the same
Trikes: All Honda: 84 250r, 85 86 and 87 250sx, 84 and 85 125m, 79 82 84 and 85 110's, 73 us 90 and 77 atc90, 75 atc70
Cycles: Honda: 71 cb100, 78 cb750 coming soon cb750 trike. Yamaha: 67 yds 3 (250cc, 2cyl, 2 stroke), 82 750 SECA
Other toys: Chenoweth VW sandrail dune buggy, old race go kart, racing mower, 76 Arctic Cat Pantera 440 snowmobile
KEEP IT ON ALL 3 OR AT LEAST 2 AT A TIME
