Originally Posted by
TwoBobRob
I don't have the answer to the original question but I can answer the automotive shoe question...
It's all about leading and trailing brake shoes. Some will be longer, some will have a thicker lining. Some, maybe both depending on design. The principle is (in simple terms) that the shoes bite into the drum when travelling forward to increase the braking effort. One shoe is pushed into the drum and the other is dragged. When travelling forwards that is. Consequently the shoes often wear at different speeds so the manufacturers counteract this by making two different shoes. In these cases, it is crucial that the shoes are fitted in the correct orientation.
This is the reason why your brakes are always worse when you're reversing.......
