Thread: My custom Vault door!!
    Mar 2008
    EastGreenbush, newyork
    3,494
    instead of framing up a wall with a regular door, I went a different route!! Figured it would be way easier to get things in and out this way( and it is) but mostly I just thought it would be cool, and I had to figure out something to do with the damn doors I pulled out of the dumpster at work lol!! after I priced all the hardware for a sliding barn door, being the cheapo I am, I decided I could Build my own!
    The doors are solid core comercial wood doors atleast 100lbs a piece. all the steel came from some scrapped electrical switch gear, sweeps on bottom are scrap coldlock pieces from a computer raised floor, all the sweet grade 8 hardware came from work. I did by some bearings for the home made roller brackets for the custom unistrut track at a cost of 30.00, 2 hose clamps for the guide castor, long lag bolts to mount the track and consumables for the project. Door is 9 foot long, slides about 7 feet. slides pretty sweet, my 6 year old has no problem moving it. Now I can keep the damn cat out of my side of the basement!! Was much more of a project than I anticipated, but I had alot of fun building it, It is definately a one off door. thanks for looking!
    All the steel is powdercoated gray, which makes it a pain to weld, as it has to be all ground off which is not easy, and anything on the backside burns off so its a bit nasty. But I have tons of raw materials from the equipment it came from, from strut to sheet metal to big beefy c channel to flatstock. It was all going in the dumpster so I stocked up!! I have been using the stuff for awhile now for alot of projects!! It was a full on work out turning in the 8- 6 x 1/2" lags into the microlam for the track!! I used the proper size drill bit acording to info I found!! I am not a small dude, and that was work!! A little tricky getting the door on the track by myself lol, especially being the four bearing rollers I made are not held in place until they are in the track but I managed!
    Mar 2008
    3,494
    the door by the workbench is stationary. Wish I took pics of the roller brackets before i put them in. you cant see the bearings in the pic, they ride on the upturned channel of the strut, there are some brass spacers visible between the bearings and the T plate I welded to. Gotta come up with a locking mechanism yet to keep the kids out lol. you can barely notice it upstairs when you roll it. Very slight rumble!
    Nice Rory!
    Turn your heat up a bit and do circles for those Mig welds. You did a drooping C . I'm sure you can do better and I can't wait to ride again with you guys!!
    DC
    Mar 2008
    3,494
    I had that little mig maxed out buddy!! I stacked quite a few beads on all sides some looked much better than others. should have honestly flux cored it for a little more penetration, as I wasnt all that concerned about looks being what it is.
