Originally Posted by
barnett468
i would do the following gas level test which eliminates the need to check the float level and is more accurate. It should also be done prior to jetting and with the gas on.
Gas level check
1. Get a small 10” long piece of clear plastic tube.
2. Connect it to the float bowl drain fitting.
3. Hold it close to the carb with the open end even with the top of the carb.
4. Open the gas valve on the tank and drain screw on the carb bowl.
5. The gas in the tube should be from even with the bottom of the main carb body to 3/16” below it. If it is outside this range, i would correct it.
