Results 1 to 12 of 12
Thread: Make a Tig Welder Out of a Alternator
    Dec 2003
    83
    i found this thread and i am thinkin about going to junkyard tommrow and making one!!!badazz http://www.turbomustangs.com/forums/showthread.php?s=567dd3ac4f2b3ae33138b7966f49adcf& threadid=8872&perpage=20&pagenumber=1
    Owner of:
    85 125M
    01 Polaris Scrambler 500 2x4
    74 Honda Trail 70
    nate b is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Central WI
    433
    that guy is good
    85 atc 250r;
    PSI porting & head mods
    fmf pipe & silencer
    boysen rad valve & reeds
    38mm air stryker
    Dec 2003
    83
    im going to use a 5hp briggs engine..and a ford 130 amp alt and see how it works...his rig looks awesome
    Owner of:
    85 125M
    74 Honda Trail 70
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,239
    sorry to say.. that 5 hp briggs will not pull a 130 amp alternator ,,, the smallest 150 amp miller gas powered welder has a 16 hp motor,,,, so i think you won't get much out of it,,,,,
    Dec 2003
    83
    5.5hp Honda side shaft motor, a 2:1 pulley ratio (to spin the alternator to ~6900rpm) that'll work! or i can always go with the electrical motor....this is better than spending 1000s of $ for a tig..just make one for just under $200
    Owner of:
    85 125M
    74 Honda Trail 70
    Crash104936221 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Gananoque, Ontario
    223
    6900prm is alot i would find out what the alts rpm is when the engine is turning at 1200-2000rpm since that is the most likly peak amp output and gear to get that speed
    81 ATC200
    Ace Mon is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Ok
    Man doesnt this wreak of a McGuyver episode ? LOL
    KASEY's Avatar
    4,239
    LOL!!!!if it won't pull it at 1:1 ratio it deffinatly won't at 2:1 ... i use to have a alternator /welder setup in an old chevy truck ,, it had a 130 amp alternator with a dual pulley and the belts had to be TIGHT it needed it when you struck an arc!!!
    it was designed for emergency use only too,,, just imagine how much gas it would use ,,,, when you have a 350ci engine running @2500 rpms to weld something,,, not very practical,,,,,,,,
    Dec 2003
    83
    Ya you are right kasey....did trailprotrailpro truck get a good bead?...i just thought it looked cool to try but now that i see it..i see what u sayin
    Owner of:
    85 125M
    74 Honda Trail 70
    Gananoque, Ontario
    223
    Quote Originally Posted by KASEY
    ya but was a it a ARC welder or a TIG? i belive that the tig dosent require the current the arc dose
    81 ATC200
    May 2003
    So. Cal.
    85
    wow, that guy made a pretty good weld with that homebrew contraption!
    New Hampshire
    794
    My dad worked for a garage when I was very young and they had a old dodge wrecker... had like 400k when they were done with it (The frame was welded together spliced with swingset). Thing was a beast....Anyway at one point I'm pretty sure they had a welder running off the altenator, but I'm sure it was arc.
    They bought it for 50 bucks and went out to a field to get it. Engine started up and stuff but the frame was horrible, and the body was actually on the ground. They jacked it up and used the swingset...The truck was a damn good vehicle for them considering what they ended up with. they got it with like 280k and it was like 402k when it was done.
