Page 2 of 2 FirstFirst 1 2
Results 16 to 28 of 28
Thread: How many have done a Lifan swap to ATC70.
    sanchez's Avatar
    sanchez is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2009
    where ever i may roam
    228
    Bump start it
    Appearing since '07
    Looking for a place to happen...
    Making stops, along the way
    Mar 2013
    Baldwin, Wi
    603
    I run a SSR125 engine in mine and just bump start it in 2nd gear very easy (unless you holding the twist throttle open then she will wheelie right out from under you). I would never go back to the 70 the 125 is just way to much fun.
Name:	2013-05-05 19.17.17 (800x600).jpg
ID:	188430Click image for larger version.
Name:	2013-05-05 19.17.51 (800x600).jpg
    85 Tri-z Basket Case
    Aug 2010
    web
    79
    That's an idea. What are you guys using for exhaust? Looks like most on ebay don't come with exhaust.
    Tucson
    1,652
Name:	IMG_20130826_183748_791 atc70-4.jpg
ID:	188457Click image for larger version.
Name:	IMG_20130826_183634_216 atc70-3.jpg
ID:	188456Click image for larger version.
Name:	IMG_20130826_183616_085 atc70-2.jpg
ID:	188455Click image for larger version.
Name:	IMG_20130716_151159_634 atc70.jpg
ID:	188454I did the 110 lifan , electric start,, hauls my 240 pound butt around just fine with the right gearing! LOL..
    Tucson
    1,652
    pit bike exhaust with a little heat to get your bends works perfect.
    Aug 2010
    web
    79
    Quote Originally Posted by badass350x View Post
    So I just searched pit bike exhaust on eBay, is this what you are talking about? If so seems reasonable.
    http://www.ebay.com/itm/Big-Bore-Muf...144730&vxp=mtr
    STL
    3,560
    Quote Originally Posted by Zuplar View Post
    My buddy Kyle went with that system for his 140, like 50 shipped cant beat it. He bent it a little with some heat and it fits great and sounds mean too
    Jun 2009
    Leander TX
    2,217
    I used something like that on my TREX. Took a little heat and a little bending. I should have bent it in closer to the frame - I still melted the plastic a little:
ID:	188481Click image for larger version.
    There's a good discussion on Glamis Dunes about pipes:
    http://www.glamisdunes.com/invision/...302469&hl=pipe
    Aug 2010
    web
    79
    I'm starting to think this project is pretty straight forward and might not be too much work. Thanks for all the input. I got to go check on the frame make sure it's still in the condition I remember it and if so I'm going to start ordering parts.
    Tucson
    1,652
    Yes sir, that's the exact pipe I went with.. sounds Awesome!
    Mar 2013
    oregon
    20
    I did the 110 lifan with e start swap and had it pretty much wrapped up by the end of a weekend. Had to trim fender, had a custom throttle cable made, build battery box, heat and bend pegs a little, and a few more mods. Most could not tell it had a bigger engine. Hill climbing machine! Well worth the work!
    I used a spacer I think 3/8 to lower my foot pegs to clear the clutch cover
    tblumer's Avatar
    tblumer is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2009
    Liverpool NY
    225
    your biggest issue will be picking out the proper intake manifold. Ive done 150 and 140 swaps and usually you will have to dent in the bottom of the tank to clear the carb top. A 5 way spacer helps too.
    84 ATC 70 w/88 (for the kids)
    85 Yamaha YTM200 (Protek suspension / Tecate forks)
    74 Joker frame ATC 90 w/ 110 cdi
    71 Honda Z50AK1 Mini Trail w/117cc stroker
    CRF50 stunter w/117cc stroker
    08 Yamaha WR250X
    My feedback:
    http://www.3wheelerworld.com/showthr...89#post1080789
