Thread: I need atc 90 help. Possibly cam timing?
    Feb 2014
    Hill Country
    10
    I needed to replace my shift shaft seal so i went in there today and replaced it. I noticed the cam chain was real loose so i tightened it, i read somewere this is supposed to be done when cold it that true? I did it when it was cold could this have caused the cam timing to have been off?
    Pacific NW
    4,255
    Quote Originally Posted by AlbertB View Post
    Hi and welcome.
    See if you can click on the next 2 words:
    service manual
    Should get you to a manual.
    If yours has a cam cover that says 'cdi',
    good idea to clean it and light lube.
    I guess even if it has points, it has an advance plate in there
    with springs and rust and stuff.
    Worn chains can change cam timing for sure.
    Usually they slap so bad noise wise that we change them.
    Not sure if the manual has a 'service limit' type of measurement
    for the chain but
    someone will surely chime in.
    Jan 2013
    minnesota
    5,911
    It makes very little difference if any.
    No. See reply above.
    Does your bike actually have a problem now?
    Free online manuals, click on desired manual in blue once link opens. It might taker 15 minutes to load.
    http://www.oscarmayer.net/atc/manuals/
    Jul 2013
    mo
    327
    Ya im confused . Does it run .
    http://www.youtube.com/user/effortequalsresults
    83 atc 110
    77 atc 90
    80 atc 110
    85 200x
    85 200x
    87 250es
    79 atc 110
    1978 atc90
    1985 200s
    1985 atc70
    1983 atc 70
    Feb 2014
    Hill Country
    10
    It does. My stator unfortunately flew out of my hands fell in my tool box and a wire going from winding to winding broke. I got a new one and it starts but it boggs down when you hit the accelerator and wont go anywere
