Thread: ATC70 rear sprocket options
    theeechozen1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2002
    368
    I have a 85 125M motor in my 70.. i want to put a 428 sprocket on the back so everything matches up. What can I use?
    Will an older CT sprocket bolt up?
    It does work with the 420 rear but after some chain stretch i get some chain jumping.. since i need to swap them out now anyways I wanted to go 428 all around
    thx!
    1985 YAMI TRI-Z RZ350 POWERED
    1986 250R STOCK WITH FMF & K&N
    1986 TRX70 mini golf cart
    TRY AND CATCH ME.....................I HAVE MO CYLINDERS THAN YOU !!!!!
    I'm not sure if they make a 428 sprocket for a atc70. You might have to get one made or make one
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,248
    Honda used those sprockets on many small motorcycles too,,, maybe if you get a Honda parts guy to help you out ,, you can cross one over
    Feb 2003
    Australia
    927
    I'm trying to remember. I think one of the Honda CT90 or 110 rear sprockets have the same setup as the 70. I think they have 42 teeth and are definitely 428.
    6,811
    Take some measurements . here's a good link .
    http://www.ebay.com/itm/REAR-sprocke...5f443b&vxp=mtr
