Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Thread: 225dx running poorly
    Feb 2014
    Victoria,Australia
    878
    It's not just you thats why I asked i'm trying to find a good set up so it's not so tippy
    73 atc 70
    84 ytm 200ern
    79 atc 70
    ytm 225 dr
    atc 90
    80 atc 110
    klt 250A
    84 atc 200es
    85 atc 250es
    Apr 2007
    Lykens, PA
    87
    So the rear shock was not the factory shock? I always thought it sat low. I just thought the rear tires were bigger than factory so thats why the fenders would rub on hard compression. That was the only 225dx i ever rode so i assumed that was factory.
    Yea, the rear hubs are yamaha 4x115. I broke the centers out of the 3 bolt rims from cornering too hard. So thats why i changed to those.
    84' Yamaha Tri-zinger 60
    85' Honda ATC 70
    84' Honda ATC 70
    83' Honda ATC 70
    78' Honda ATC 70 (140cc lifan)
    79' Honda ATC 70
    73' Honda ATC 70
    85' Honda 200s
    83' Honda 200e
    85' Honda 250sx
    Mar 2013
    Central PA
    2,362
    It was from a yamaha xt100 I believe. I did some more work yesterday. Got the front brakes fixed, replaced the broken arm. Put on a new cable and brake lever. Put a new tire on while it was off since the old Carlisle was cracked and bound to pop soon or later. Early yamaha brakes still amaze me how bad they are. Hell, the front drum is not even sealed. Neither is the back I guess but that's just disc. Guess I'll try new pads in the rear and see if that helps.
    I also tried replacing the neutral lights bulb, cleaned up the connection points, still nothing. I'll have to trace it and see about the problem. I kinda don't wanna replace the headlight since I'll need to splice it in since the plugs were cut off. That's for another day though.
