Results 1 to 9 of 9
Thread: exhaust question
    Mar 2014
    exhaust question
    i want to get this exhaust http://www.ebay.com/itm/HONDA-ATC-20...-/151243740353 for my 83 honda 200x thats stock would i have to upgrade anything and is it just bolt on?
    Sep 2011
    New Castle, PA
    1,134
    I have not used that exhaust specifically. but when I went to a different aftermarket exhaust I found that lowering the clip on my needle down a notch in the carb helped richen the mix a little and it ran better. If you need help doing what i explained just ask, I can go into more detail.
    You asked if its bolt on. Yes, it is.
    Just saying, though, you can save 100 and get it in a black painted finish. Your money, not mine though
    Gone:
    Feb 2014
    Davenport, Iowa
    69
    I'm still dialing my bike in with the painted version of that pipe.
    You'll probably have to tune the carb a bit. The downside is no spark arrester and it's LOUD. Harley with drag pipes loud.
    Dec 2013
    Ohio
    110
    nto arrestors as i have this pipe too... move up to a 110 -112 main jet....sounds awesome not too loud but a nice bass to it>>>>
    Ride Red!!!!
    Dec 2013
    Ohio
    110
    looking into the cone arrestors that DG makes for these...as i have this pipe too... move up to a 110 -112 main jet....sounds awesome not too loud but a nice bass to it>>>>let you know what i find......
    Ride Red!!!!
    Jan 2014
    Buffalo, New York
    11
    So with no arrestors you can't ride in parks.Does it effect performance?
    Mar 2014
    What exactly is a spark arrestors
    Sep 2011
    New Castle, PA
    1,134
    When you run, sparks can fly out of the end of a un-protected exhaust. If they do, they can catch things on fire. So they stop you from burning your local forest down, and they quiet everything down a bit. They can be simple.
    Gone:
    Mar 2013
    Wausau, WI
    147
    I have that exhaust with the black finish on my 200x, if you're gonna get it make sure you get the chrome finish. I only had the exhaust on the trike for not even a year and it's getting pretty rusty, very poor finish, the chrome should be more durable. It's a little loud but performance seems good.
