Results 1 to 2 of 2
Thread: NEED 350X rear axle.
    Nov 2013
    El Paso TX
    52
    restoring a 85 350X with an 86' motor and rear end.... put ALL NEW parts back together and looked like the sprocket was bent but after inspection turns out the pressed on piece the sprocket bolts to is the one that isn't true. unfortunately all the junk I find on ebay is over priced... private msg or post back on here with some options would appreciate it.
    Nov 2013
    El Paso TX
    52
ID:	189274 before..... Click image for larger version.
ID:	189275 almost done.
