Results 1 to 11 of 11
Thread: (Need Help!) 1984 Yamaha Identification
    Dec 2013
    West Virginia
    101
    Hi everyone!
    I just purchased my second 'big' three wheeler last night! I got it for $350. I need some help identifying what exactly it is. I know that it's a 1984 because of the EPA exhaust sticker says "this 1984 Yamaha blah".
    I have no idea if it's a Tri-Moto or Tri-Zinger or what?
    Here's some pictures:
    http://imgur.com/a/qw8s5 (I can get better pictures if needed. These were the ones that the seller had)
    After reviewing my old thread about it (before I bought it), a member Chopsaw posted a picture of his:
    I'm fairly sure that they are the exact same bike. His comments in my old thread were: "I bought a 84 200e Yamahauler that was sitting in a barn for 250 with
    original title . Cleaned it up , dialed it in and flipped it for 600 . I liked it , but Bigred was jealous .
    Go look , and if you're not sure take pics and ask here . I'd like to see it ."
    Also, what's the difference between the 84 200e and just an 84 200? Electric start? Could I use an 84 YTM200 transmission (read below)?
    Other information on the purchase:
    -no electric start (not sure if it ever had one)
    -the key is the size of a lawn mower key, I'm pretty sure he makeshifted it
    -the key stays on 'on' and if you turn it to 'light' it will shut off. It will not go turn to 'off'
    -I'm not sure what the neutral on/off indicator did/does, but it doesn't seem to take affect or do anything
    -the headlight and taillight are not hooked up/functional
    -I'm not sure if it has a battery, I'm still trying to get the seat off .-.
    -the rear footbrake cable is gone
    -the transmission seems to be 'jerking' in first gear. It will grind and have a popping noise all throughout every gear. I know this is a huge issue, and I was unaware of it at the time of purchase. It was midnight out and I didn't get to drive it for more than a minute, kind of just took the guy's word.
    Any help and information would be much obliged!
    EDIT: Here's a video of the transmission http://videobam.com/XFNZy
    and here's some more pictures of the trike
    http://imgur.com/a/p3KVw
    Proud Owner of:
    1986 400ex Frankentrike
    1986 Honda ATC 350x
    1987 Honda Big Red 250ES
    maxdallasfan's Avatar
    maxdallasfan is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    New Jersey
    381
    The seat is attached to the rear fenders. There is a lever by the grab bar that un hooks it all. Pull up on the fenders then slide back after pulling on the lever.
    200e is electric start. Prob. Has reverse too.
    A 200 is pull start, no reverse. I think.
    My ride:
    1985 Honda 250es
    May 2013
    St. Louis
    505
    1984 200E shaft drive , electric start no reverse . Turning the key to light , is just to work the light , bike wont run , or at least mine didn't .
    emmie357's Avatar
    emmie357 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2013
    Upstate NY
    214
    Yes, it's an 84 200e if it has the neutral switch. Should also be a hardtail with shaft drive. Battery box would go on the left side of the frame (looking forward) under the rear fender against the frame.
    Electric starter should be a big cylinder looking think under the exhaust port. They didn't get reverse until 85.
    A key about the size of a lawnmower (tractor type) key is correct.
    The "light" key position is to use the light with the vehicle off, it needs to be set to run to actually run.
    There should be a headlight switch below the kill switch to use the headlight while running. (also where the start button should be)
    Neutral light should come on when in neutral with the key set to run (and a charged battery). The e start is tied to the neutral switch and it won't work if that light is not coming on (unless you wire around it).
    Tranny issue don't sound good. But I think I hit most of your questions...
    84 YTM200E "yamahauler"
    85 YTM200
    85 KXT250 Tecate
    glendive, montana
    1,822
    you can use any 200 or 225 transmission, they are the same out of the ytm series. the key issue can be easily solved my guess is they replaced with one off of a banshee or a 225 at some time if you only have 2 positions, if you want send it to me and I can change it to a 3 position switch and send it back to you plus check and see if you have the right connection on it for your 200e just pay the shipping.
    Dec 2013
    West Virginia
    101
    Added a video of the transmission issue and some photos of the dash and key
    Proud Owner of:
    1986 Honda ATC 350x
    glendive, montana
    1,822
    ok the tranny video doesn't work for me, but I can tell you that is not the right key for your trike. this is what you key ignition should look like. Click image for larger version.
ID:	189958Click image for larger version.
    9,020
    Nice shape!
    Dec 2013
    West Virginia
    101
    Quote Originally Posted by muthey View Post
    Here's the video: http://videobam.com/XFNZy
    It should work now.
    Proud Owner of:
    1986 Honda ATC 350x
    glendive, montana
    1,822
    before tearing into transmission I would pull the rear end and drive shaft and check there first.
    Dec 2013
    West Virginia
    101
    Yeah I've had a bunch of people tell me that on a Facebook page. I'll definitely check the rear end before tearing into the transmission.
    Proud Owner of:
    1986 Honda ATC 350x
