Page 4 of 6 FirstFirst ... 2 3 4 5 6 LastLast
Results 46 to 60 of 79
Thread: Is this trade worth it?
  1. #46
    Jul 2011
    Burlington iowa
    134
    Well figured out how to find tdc but the little plug to see the marks wont come out.
  2. #47
    Mar 2013
    Central PA
    2,362
    I used a dull chisel but any thick flat head screw driver should do and take a to it and it should come out.
  3. #48
    Jul 2011
    Burlington iowa
    134
    tried that it didn't work that thing wont budge
  4. #49
    Jul 2011
    Burlington iowa
    134
    got it loose and got the timing set runs great and no leaky valve cover now
  5. #50
    Jul 2011
    Burlington iowa
    134
    Might be trying to save this old 70 to mess around with also is this a first gen 70?
  6. #51
    Feb 2014
    Victoria,Australia
    878
    yes it is a first gen I would say its a 1974 model
    73 atc 70
    84 ytm 200ern
    79 atc 70
    ytm 225 dr
    atc 90
    80 atc 110
    klt 250A
    84 atc 200es
    85 atc 250es
  7. #52
    Mar 2013
    Central PA
    2,362
    Quote Originally Posted by Dustin96 View Post
    Hope your getting it cheap. Tires look good though so thats a plus. The recoil might be a problem, expensive but im sure someone here has one. Lots of paint removal to do. Unless you dont care. And a seat cover. Plus fenders if you want it pretty.
  8. #53
    Jul 2011
    Burlington iowa
    134
    nvm i passed on the 70 dude wanted way to much he wanted $300
  9. #54
    Jul 2011
    Burlington iowa
    134
    Ok after running the big red if i check the oil when its warm some pressure comes out the dip stick hole is this normal? Also the starter doesnt work but its always spinning when motors running is that bad?
  10. #55
    Jan 2011
    Greene,Ia
    688
    pressure coming out of the dipstick hole isnt good, but could be an easy fix. im guessing the crank case vent is clogged. should be a little fitting and hose somewhere in the middle of the crankcase under the carb area and probably behind the starter somewhere.
    yes the starter running with the motor running isnt good. you have a bearing shot somewhere. like some have mentioned the one way bearing is probably shot. youll end up destroying that starter running it like that.
    2006 Yamaha Raptor 700
    2004 Kawasaki KFX700 V Force
    1985 Suzuki LT230GE(wifes toy)
    1985 Honda ATC 70
    1979 Honda ATC 70 (daughters toy)
  11. #56
    Jul 2011
    Burlington iowa
    134
    alright ill check that vent and I cant afford to fix the starter right now can I just remove its gear?
  12. #57
    Mar 2014
    South Chicagoland
    35
    Quote Originally Posted by Big G View Post
    You have a nice 90 there, but both of the 200E's look pretty much complete - so I'd say it's a decent trade. The plastic and rubber looks good on both of the 200's. The 200 engines are skookum. Like you say, they'll need a bit of tinkering, but it won't take much to get a decent runner going. I think you'll be happy with the upgrade. Besides, half the fun is working on these things!
    On a side note, how can someone just abandon these trikes to the elements like that (sitting in the snow drifts). Man, it's almost criminal to neglect them in such a way.
    I know, how can they do that? One of my freinds (as I just recently discovered) has a 250r that he just left outside in the weeds for eight years. Now im gonna fix it up for him out of pity for the machine. It just makes me sad to see it sitting outside.
    250sx, atc70, atc125m
  13. #58
    Jul 2011
    Burlington iowa
    134
    Im gonna try to fix the electric start I guess my backs been killing me and im tired of pull starting it in pain. Is there a trick to get these starter clutch off mine wont budge.
  14. #59
    Jul 2011
    Burlington iowa
    134
    Well guys the wait is finally over I got updated pictures! Ignore my messy yard lol
  15. #60
    8686 is offline First Time Rider Arm chair racerNew to the board
    Oct 2012
    MI
    97
    Hope it works out for ya.
