Don't look too bad other then the front rack being bent. Looks like a nice rider, plus you won't get stuck with them tires. Must make for a rough ride though. My back wouldn't be able to handle it lol.
Tires actually ride fairly smooth over 5-10mph and ya rack needs some help thats the next project.
Oh and is there a skinnier front tire that will fit this?
any ideas on the front tire?
I think 25x12x9 is the stock size, I can't remember off the top of my head. I would stick with that size and look for a skinnier profile tire. You'd be surprised the actual size difference between manufacturers with the same size tire.
Personally I like the knobbies on the front like Carlisle or Cheng Shin.
82 250r
83 Big Red
85 Auto-x
If you've done business with me please leave me feedback
http://www.3wheelerworld.com/showthr...ght=Bren_downe
ok I was just trying to find something around 8" wide so I could have matching widths front and rear ill look into one of those brands tires thanks.
can anyone tell me about how wide the cheng shin knobbies are inflated?
sorry I haven't updated this in a while but I got the crankcase pressure building up fixed it was a plugged vent lines. I also ended up trading the parts atc because its motor needed a lot more work then I first thought. I got this on tradeits runs doesn't smoke just isn't the prettiest and the shifter splines are stripped.
Has anyone made a case saver for one of these big reds? After getting the new tires Im worried about throwing a chain threw the case.
Also is there any power mods I can do to the engine? With the new tires it seems to be running a little lower in torque then I would like.
ive been riding it for awhile now and just think it could use some more power for the steep hills, do they sell bigger rear sprockets for these anywhere? Or am I stuck to just engine mods for the extra power I need?
you can get larger rear sprockets, but will need to remove the chain guard to use them. check on ebay
ok ill look and the chain guards no big deal ill just weld up some kind of skid plate so I don't bounce the sprocket off stuff.
What is the stock front and rear sprockets on the 1983 200e big reds?
