Have any of you guys used these on a stock 20" GM rim on a 2007 to 2013 truck that was NOT lifted? If so, was there ANY rubbing and what was the road noise like?
Thanks!
EDIT: Toyo 285/55/20 AT II
Thanks!
That was stock longer than I thought it would be ....![]()
Thats the same size that came on my 2010 from the factory. Mine were Goodyear Eagles though. You shouldn't have any issues running that size.
1974 Honda ATC 70
1985 Honda ATC 250 ES Big Red
1986 Honda ATC 250 ES Big Red
2008 Honda Rancher 420
1983 Hustler 945-HK 6x6 - Fire Breathing 627cc V-Twin Monster
2010 Chevy Silverado 1500 4x4 LT
1983 GMC K10 Sierra Classic Suburban 6.2 Liter Diesel
My Feedback:http://www.3wheelerworld.com/showthr...-for-Stonewall
There is no Z in Diesel!!!
Nothing crazy, just the essentials:
Ball hitch
Bed rails
Under rear seat storage tray
Mud flaps
Rear inner fenders (I changed my mind about the painted look)
... and looking into the larger more aggressive rubber, but I think that will be it while it's still under warranty. The Magnuson Moss act is not respected here, so I’ve got to keep it all original GM, but damn those 285’s looked good rolled up to the body. The thing is that the 275's on the Av had about .001” clearance from the mud flaps when turned and I don’t want rubbing and can’t raise the body under warrantee. Hoping someone here has do it.
Now that you mention it, maybe they were. It's been so long I can't remember. There's only 10mm (.4 inches) of difference in the sizes though. The next set I got were 285/65r20, and they did rub, even with 3" leveling blocks. I think you will be fine with the 285/75's.
1974 Honda ATC 70
