Results 1 to 12 of 12
Thread: Help Please!!! What offset will fit the 1985 Honda Big Red 250es
    Mar 2014
    Florida
    6
    Hello All new to the forum here.
    I just bought a 1985 Honda Big Red 250es and I would like to put a more aggressive tread on it. I would also like to change out the rims. The problem I am having is I don't know what kind of rim I can put on the front without it affecting the brakes and causing the tire to rub. Any light you guys could shed on this would be greatly appreciated.
    Thanks
    Newbie.
    Stonewall's Avatar
    Stonewall is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2011
    Bryan, Texas
    405
    The search feature is amazingly useful for finding out information about things that every new guy makes a new thread about.
    http://www.3wheelerworld.com/showthr...d+wheel+offset
    The stock wheels are 9" wide with a 3+6 offset. So if you had a 7" wide wheel (most modern ATV wheels are) you need a 2+5 offset.
    1974 Honda ATC 70
    1985 Honda ATC 250 ES Big Red
    1986 Honda ATC 250 ES Big Red
    2008 Honda Rancher 420
    1983 Hustler 945-HK 6x6 - Fire Breathing 627cc V-Twin Monster
    2010 Chevy Silverado 1500 4x4 LT
    1983 GMC K10 Sierra Classic Suburban 6.2 Liter Diesel
    My Feedback:http://www.3wheelerworld.com/showthr...-for-Stonewall
    There is no Z in Diesel!!!
    Mar 2014
    Florida
    6
    Stonewall thank you for your reply however I am trying to avoid the rubbing issues that you have encountered (I also don't want to use a spacer . I understand how the search tool works and actual read the threads you posted but avoided them because of the rubbing issues you'd mentioned. Also I believe the stock rim offset is 3+5 not "3+6" (http://www.rockymountainatvmc.com/Bu...kage/723/31259).
    Thanks though
    Stonewall's Avatar
    Jun 2011
    Bryan, Texas
    405
    I don't have any rubbing issues, I just can't run fork boots with the Vampire in that particular size. The size I'm running is (I think) one of the widest ATV tires on the market. Other sizes ain't a problem. 25x12-12 Vampires and 26x12-12 Mud Rebels and Anclas fit with no problem. And no, it is a 3+6. The stock wheel is 9" wide (I own over a dozen of 'em); offsets are measured as the hub side+front side. 3+5 equals 8, which is not equal to 9, so thats impossible on a 9" wide wheel. My recommendation is a set of 26x12-12 of whatever you want on a set of 7" 2+5 wheels. That combo will work fine on a stock 250ES.
    1974 Honda ATC 70
    Apr 2012
    Georgetown,Ca
    101
    I've had good luck with rear rims all the way around from an 05 trx 400, they're 11x7.5. The front needs a slight 1/8 inch shim to center it perfectly.
Name:	big red 250 001.jpg
    Sarnia, Ontario, Canada
    3,415
    I have a fair bit of experience at this as I have had a great deal of fun experimenting with tire/rim combos for the ES and SX machines..
    The rim you are looking for is off the shelf, cheap and don't need to be shimmed to get the front offset right. The ITP Steel 12x7, 2+5, 4/110 rim is a direct fit for the Big Red..it can be found at many retailers for about $35/rim
    http://www.amazon.com/ITP-Delta-Stee.../dp/B002OKHNMC
    Then you can experiement with a multitude of different 12" tires..I like the 26x12x12 for rear and the 26x8x12 for front. BTW, when you install the front tire, if it has a directional tread be sure to mount it on the rim as a right side tire to get the tread direction correct for the front.
    Here are a few of the machines I've done this with..have fun!!
ID:	190619Click image for larger version.
ID:	190620Click image for larger version.
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Legns is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2014
    Catskills NY
    156
    Quote Originally Posted by dougspcs View Post
    Thanks for that link I have been searching the threads for something else and saw a pic of a really nice 250es all done up and loved the way those look. It might have been yours Since then I have not been able to find them so that just made my day
    Jan 2014
    La
    1,062
    hey man if your rims are still good and not rusted out why change them?
    Aug 2014
    Catskills NY
    156
    Quote Originally Posted by 86125m View Post
    My rims are pretty beat up they are fine for now but when I do the resto on my trike is when the will go on
    Nov 2020
    Seneca Pennsylvania
    3
    1985 250ES Big Red
    dougspcs, I'm going to be getting new tires and wheels for my 85 Big Red 250ES, I want to go to 12" just like the ones you suggested (ITP) steel. I can use 3 of those wheels and put 26X8X12 tires on all 3 with no issues correct?
    I understand running a wider tire in the back but is it necessary? Just looking for some opinions, Thank you!
    Willie250ES
    Last edited by Willie250ES; 11-03-2020 at 12:14 PM. Reason: forgot to copy original message
    Nov 2020
    Seneca Pennsylvania
    3
    So I should be good running 3 of the wheels you suggested with 26x8x12 all the way around on my 85 250ES right? is it just a preference to have the bigger back tires? and do the rims change width as well? thank.
    Willie250ES
    Jan 2023
    Texas, United States
    Sx front end swaps? For a 26x9-12
    Have any information for the correct offsets for a 26x9-12 tire for the Honda 250sx
