And yes I've scoured the forums and talked to some highly knowledgeable folks via PM. Lot's of great information trying to sort this out
Here's what I got happening - Parked it one day, no spark the next. First thought, CDI. Tried testing the CDI as per the manual, but got some goofy results. Seems like a common issue with the test procedure in the manual. Got lazy and ordered a re-pop off eBay. Still no spark. Lesson learned, INVESTIGATE!
BTW, the electric start works great and the headlight, tail light, neutral/reverse lights work. I've tried disconnecting the ignition switch and kill switch ground. No change. I've disconnected the reverse lock out and jumpered the neutral switch to ground, no change.
I'm getting 30V AC out of the exciter at full crank with the spark plug out but 0 ohms resistanceMeasuring the resistance is the only test in the book?
Pulse generator resistance is 29.2 ohms = good
I removed the coil and spark plug boot like the manual states, .3 ohms primary, 3.94K ohms secondary = good
I get continuity from the exiter wire to the CDI
I get continuity from the CDI to the primary wire on the coil.
Every wire I remove I clean up and cover with dia-electric grease
Not too sure what else to troubleshoot?
I'm leaning toward the exiter coil, thoughts?
