Results 1 to 8 of 8
Thread: Front end swap
    Dec 2013
    bayshore,n.y. USA
    19
    Front end swap
    Hello all 3 wheelers
    do any of you know if a 84 honda 200 s front end will fit on
    a 84 honda 200 es, also what is the biggest tire that can be mounted on a rim
    size 8.25 x 8.0
    any information will be greatly appreciative
    Oct 2013
    Wherever I May Roam
    3,757
    12" wide is gonna be about the max on an 8" wheel. Height will be limited by the fenders and the trikes actually ability to turn the tires.
    Dougspcs might stop in and give a recommendations on bigger sizes, but I think most people consider 27" tires to be overkill for a regular rider, so keep em 25" or less in my opinion.
    I'm going to take wild guess and say that yes the S frontend will fit on the ES, but I'm not a utility trike expert by any means.
    I do know a good way to find out though........
    Jan 2014
    La
    1,062
    The 200s front forks are smaller than than the es. So I don't know what's wrong with your front to make you want to swap them.
    Sarnia, Ontario, Canada
    3,415
    Unfortunately the 200es doesn't use the standard 4/110 bolt hub so change ups to the stock rims are VERY limited..if they exist at all.
    Front end swaps aren't my area, I've never done one so I can't offer any input to this project.
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Dec 2013
    bayshore,n.y. USA
    19
    The 200 es forks are shot - shocks are junk, if you want to call them shocks; I got the 200 s forks cheap and they are in good shape- the shocks are good, and I was having a hard time finding a good 200 es front end in good shape that was a good price
    If it does not fit up, I will have to keep on looking for a good 200 es--THANKS
    Jan 2014
    woodland, indiana
    20
    I may be wrong here but doesn't the 200es use the loose balls for neck bearings and the 200s use a tapered bearing?
    Nov 2013
    Benson, AZ
    147
    My '84 200s uses 21 (IIRC) loose balls for the neck bearings. Can't help with whether or not it'll fit on the 200es.
    Oct 2013
    Wherever I May Roam
    3,757
    And again, easy way to find out, takes about twenty minutes.
    Put it on there and see.
