Results 1 to 7 of 7
Thread: 1985 ATC250r - China Aluminum Rads - Anyone use? Are they any good?
    Feb 2014
    Winnipeg, MB
    62
    Looking to upgrade the look during my mod restoration. Seen these on evilbay pretty cheap. Are they junk? I've attached a pic for reference. Price range from $149 - $200 for the set. They all look identical and probably manufactured in the same plant.
    Let me know if you have had any poor experiences.
    Thanks,
    Description on ebay ad:
    "Oversized Aluminum Radiator Honda ATC250R including both left side and right side radiators
    Fits: Honda ATC250R 1985-1986
    The radiator is a oversized radiator which has 40mm thickness and a 30% extra capacity which allow more cooling liquid and a better cooling ability, this will also hold a stronger engine and help the performance of the engine! The radiator is fully aluminum, all are welded together, we never use any glue or epoxy! Excellent products with high performance, 1 year warranty!!"
    STL
    3,560
    I want to say that Tom PocoLoco is running a set on his BDT 250r, i havent seen feedback from him though. Im almost positive i saw him post that on facebook that he was going to try a set out though
    Mar 2013
    Victoria BC Canada
    32
    Personally I would not put china made equipment on any of my bikes if I can help it!! Wonder how much a local rad shop or fabrication shop would charge to build those one off?
    Jan 2011
    Choctaw, OK
    2,755
    I put set on my R before I sold it. No issues other than the cap is hard to get off because the rads are a bit taller.
    Mar 2014
    san diego
    I was wondering the same thing, although I don't like the fact that they are made in china. Certainly look trick though
    devore,ca
    1,044
    I am running them on my R. Only because I am trying to pull more heat out of it after going to a 330 big bore.
    I have to remove the right shroud to check or add coolant, and it hits my fmf pipe. If it is a stock motor I would stay with the stock rads.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Mar 2014
    I put a set on a crf250 I had a couple years ago and had no problems with them. I would like to eventually build a 250r one day and am thinking about these for cooling system.
