I picked up a 1985 atc 350x and it needs a rear axle bearing holder. Anyone have one they would part with..? Paypal ready
Thanks..
Thanks..
Just go on ebay and buy a new duel row carrier, comes complete with bearing and seals, for under $90 shipped. On the 85 you will need to run the later style sprocket bolts. I believe it is the same one that the 300ex and the 250x use, that is why they are so cheap.
Rebuilding and riding trikes everyday and lovin every minute.
http://www.3wheelerworld.com/showthr...light=pipeline
Thanks for the info.. So if I run the same set up as my 86 350x I should be good?
Current trikes
1985 350X
1986 350X
Searching for 85-86 250R
little late... I just sold a complete rear end with shock for 200...
350cc's of Pure Adrenalin'
'85 350x
'85 Big Red 250
Does anybody know exactly what I need for the newer carrier.. Thanks
Current trikes
1985 350X
1986 350X
http://www.ebay.com/itm/HONDA-ATC350...06525e&vxp=mtr
I just did one a few weeks ago get one of these 86' style carriers off ebay or somewhere similar and an 86 style sprocket (allows for bolts to be countersunk) and I think it was 4-6 o rings. very simple! I just looked at the diagram of an 86' 350X rear end on bikebandit.com and ordered all the O-rings for like 15$. but those carriers like I bought come already pressed with bearings and seals just add grease.
Thanks man, just ordered one from that link...
Current trikes
1985 350X
1986 350X
Good stuff man glad to help. If you r like me I took mine apart and looked to the manual to put back together, not much use u gotta look to see where the O-rings do "belong" but deff tighten down axle nuts to spec! good luck!
