Hello - what is the correct procedure for draining the cooling system on a '85 Honda 250R ATC. No access to a repair manual. Just want to make sure I am not missing anything and doing it right. Never had to do this on my '84 200es (LOL) Am I correct in taking off all the rad hoses and draining the rads, removing the drain screw in the cylinder block (left side) and removing the drain screw in the water pump??? Empty the coolant reserve tank, too??? Will this procedure drain the entire system??? When I purchased this ATC from the original owner last weekend, I asked when the coolant was last changed. His reply was that he was not sure. I want to have fresh coolant put in. Also, how much does the entire cooling system hold??? Thanks in advance, BK3
