200x Installed OEM Carb...Question?
Hey Guys,
I installed the carb and it made a huge difference! I have a DG exhaust so I put a 112 main jet and took out the 108...Seems to be responding well with power and no choking or hesitating. Question : my airbox tube seems to barley fit on the carb and I think Im getting air as it revs downs a little slow...any suggestions on how to fix that? Also are there any gaskets besides the 0 ring gaskets that need to be installed in the manifold carb pipes? And is there any adjustment needed on the carb air/idle for the 112 ?
Thanks, Jay
Ride Red!!!!
The air tube fits very tight on the carb. As far as the slowing idle, have you checked your throttle cable to see if it is sticking. There should be one o-ring at each end of your intake tube with no gaskets.
//ArrowChat Integreation Code
