Tried pressing my 85R steering stem back into the triple tonight but seeing how the triple is not flat at all it just keeps pushing it around at an angle, whats the trick? thanks
86 350X ::: 85 250R
Projects
350x
Come and Gone
86 350x : 84 250r X2
85 350x X2 : 84 200es X3
83 200e : 78 ATC90
What year? Can you post some pics? I'm not sure why you would be pressing anything other than the bottom bearing on an 85-86.
You may need this tool to install the lower bearing.
http://www.rockymountainatvmc.com/p/...ng%20installer
freeze the stem and heat the bottom clamp in the oven to about 350-400 degrees. falls right in after that. Be sure to use gloves![]()
well I don't know if it was damaged when pressed out or something (looked fine) but I just gave the heat and freeze method a go and ruined it. stem went in about 1/4 of the way then wouldn't budge, even with the use of a. my advice is don't press out your stem unless you have to! hahaha
86 350X ::: 85 250R
Projects
350x
Come and Gone
83 200e : 78 ATC90
Bush from the bearing surface on the top (Directly around the stem hole), not from the sides where the forks slide through and then it'll be straight.
