Thread: 1979 ATC 110 front rim
    Apr 2014
    Louisiana
    53
    Hello. I am searching for an aftermarket rim to fit the 1979 atc 110's 3/100 bolt pattern. I have found rims that will fit the rear, but I am also looking to replace the front rim and have been unable thus far to find a rim appropriate for the front. From what I understand, the rim needs to be a centered rim. Any suggestions on what I may need to be looking for in rim specs to know if it will fit the front, or any suggestions on where I could find an appropriate aftermarket front rim?
    Thanks
    Jan 2014
    La
    1,062
    You are going to have a very hard time finding a rim with that bolt pattern and be centered. Trust me I learned the hard way. What's wrong with the original rim if its not rusted out on the inside just sand prime and paint it to match the rear rims that's what I did.
    Apr 2014
    Louisiana
    53
    Aren't they split rims? As far as I know the rim is fine. I just wanted to replace the spilt rims with solid rims.
    Carthage NY 250r rules
    2,355
    You can get rims for the 81 250r that are aluminum 3/100 .This rim should also fit the 110.
    250r rules
    6,808
    The 3x100 8" centered rim is an easy find LOL . DRATV has them in alloy and at a good price .
    http://www.dratv.com/poalwhbydo83.html
    Apr 2014
    Louisiana
    53
    Thank y'all!!
