Results 1 to 15 of 20
Thread: Do you guys like it WIDE!!!!!!!!!!??
    Pulled it out today after maybe 4 years, 2nd kick........
    honda3's Avatar
    honda3 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2012
    maine
    232
    Where did u find an extended axle for an 86?
    My 3 Wheelers
    1986 atc 200x(garage queen)
    1985 Honda 250sx
    1985 Honda Big Red
    1985 honda atc 70 breast cancer build
    1985 yamaha tri-z 250
    1985 Yamaha yt 60
    1985 yamaha yt 60
    1984 Honda Atc 70:
    1984 Honda atc 70
    1984 Yamaha Yt 60
    1983 Suzuki alt 50
    1983 atc 200x
    1983 atc 185s
    1982 yamaha yt175
    1982 atc 200e rider
    1980 honda 185(all original)
    1978 Honda atc 90
    NEPA
    7,051
    Great ride Steve O !
    Jul 2012
    Joplin, MO
    597
    Nice.
    What kind if tires are on it?
    4 years? That thing was at Trikefest last year. 4 years, 10 months, close enough I guess....
    Jun 2003
    englishtown NJ
    2,676
    those tires are bandits, they are made pure sport. 86 200x extended axles are out there. I got one in 04 from Inland Atv, NOS. A more realistic option is get a stock 83/84 250r axle, its the same width as a +4 86/87 200x axle. You will need 38 tooth or so sprocket for a 83/84 250r, sidewinder makes a real good one, its expensive though. Brake hub fits, wheel hubs fit and everything lines up. You will need to grind the carrier to clear the sprocket bolts.
    Oct 2006
    2,504
    Yes, YES I DO!!!
    Jun 2003
    englishtown NJ
    2,676
    I recently changed mine to put a 86-89 250r caliper on it. Caliper stay for 86-89 250r fits with a slight bend. You need to remove 20mm diameter from 86/87 200x or 85/86 350x disc and space out the caliper ~1/2". You also can use a 83/84 250r or 83-85 200x disc and carrier and grind them down 20mm is diameter, then have to space out the caliper ~3/4". Far Far better brake.
    Sep 2011
    New Castle, PA
    1,134
    I've found +6 axles but nobody wants to sell them cheap. I want someone who doesnt know what its worth, is that a bad thing lol:?
    Gone:
    Nov 2006
    Tulare, California
    719
    Just from the back that looks like a pretty sweet trike man..
    Current Bike:
    1985 Honda 350X
    Bikes owned:
    1984 Honda 200X
    1982 Honda 250R
    1985 Honda 350X x3
    1985 Honda 250R x2
    1985 Honda 500X
    I'm an idiot. I didn't even realize that was the 200.
    Mar 2012
    Glen Rock, PA
    551
    Dude, not cool...only one pic? That's like late night cable where they only show 2 min of the nudie flick then cut it off and make you pay for the rest. Such a tease...
    Ragin' full on...
    OHIO
    2,857
    No sir, I brought the 2 350X's. That 87 12:1 ported/ST exhaust/ 200X motor needs race gas and I finally got an FCR carb for it to dial it in recently; Just need some jets
    That 200X went to TF when I built it in 20 days, remember?? There are like 10 hours on that motor, it is SUPER quiet!
    I'd like to bring that and the RX this year instead of the 2 3-fiddys (if we have room). It's up to you bud
    Anyhow, I have 3 extended axles for it. I'm taking out this WIDE one for a plus 4 overall. This is just SIC too wide
    Blossvale NY
    4,563
    Wide you say? That's the only way to have em' Steve! The way they should have been made from the get-go....
    Kind of hard to tell in the pic, but that is +6
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
