Results 1 to 2 of 2
Thread: honda 200x transmission or clutch? what died on mine any help is nice
    Sep 2013
    oregon
    15
    i have a 1985 200x with a 200s engine mounted in it the other day i was hitting trails running it pretty hard and it was fine then after a run i parked it for a min. i let someone els ride it and they were in 4th gear going like 5 mph for like 15/20 min i got back on it and it felt like a brake was locked. in first gear didnt really want to move i adjusted the clutch nothing same thing but in nutural it roles fine.I decided to just run it, had little power and felt jerky (almost like a brake being applyed then not) let it sit for a min then tryed it again ran perfect for about 1/8 mile then bam the jerk came back and little power does it sound like the clutch is toasted or is it time for crankcase seals im new to centrifugal clutchs its not the brakes and the engine is trying hard to move it
    Jan 2011
    Brazil, Indiana
    2,087
    Sounds like he glazed the clutch fibers. You can probably scuff them lightly with emery cloth and fix
    Them. Might as well replace them since you are in there.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
