Results 1 to 15 of 24
Thread: what engine powers the 200x best
    Sep 2013
    oregon
    15
    iv herd alot of people say that the 200s engine is better then the 200x engine when it comes to driveability and get up and go power. What engine drives the 200x beast best. 200x ,200s ,185s iv out ran a few quads in a 185s even with the balloons
    Sarnia, Ontario, Canada
    3,415
    I wouldn't really say this swap is done for performance reasons since for the track and trail the 200X manual engine is preferred by most..
    The 185 & 200 series engines are common replacements for people wishing to create the AUTOX trike.
    Simply take a 185 or 200 engine from any other chain driven model and install it in a 200X..this is done to get the auto-clutch and because when their 200X engine dies the 185/200 are still quick common and easy to find.
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Oct 2013
    Wherever I May Roam
    3,757
    As far as bolt ins go, the largest and most powerful one I have is a 229cc manual clutch with reverse.
    Don't think anyone else has one yet, at least I haven't seen it.
    Sep 2013
    oregon
    15
    yeah i have a 200s in my 200x right now i didn't do it for performance i miss the 200x engine that was in it just seeing what other people prefer
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by pbilt155 View Post
    Slidell, LA
    4,738
    a 200x engine....
    Feb 2013
    Ontario
    812
    The gio 250cc 4 stroke engine with electric start bolts right up to the frame. Not the best but still a option.
    Apr 2010
    Indian Falls, NY
    1,289
    People put in "S" engines for the auto clutch but for those that prefer a manual clutch the original engine is my personal preference.
    Oct 2013
    Wherever I May Roam
    3,757
    Quote Originally Posted by Troyg25 View Post
    Have you done this swap yet? I havent seen a gio bolted in yet but i just did a swap with a similar engine and it is not a direct bolt in, as the upper mount plates from the 200x will not work.
    the gio is also actually a 233cc engine, even though they call it a 250.
    Carthage NY 250r rules
    2,355
    The 200x.All three of these motors are great. As far as get up and go the 200s is last of the three.Then the185s, 200x being most powerful . I have a 83 auto x with a 185s motor and a 200x.In a few weeks I will run them against each other and see whats up.I can set them up to be exactly the same meaning tires and gearing.This is just my 2 cents.
    250r rules
    Oct 2013
    Wherever I May Roam
    3,757
    Tires yes but gearing would be a challenge to match exactly, due to the trans gearing.
    Its no secret that a good running 9.6:1 200x engine is going to beat a good running 8:1 200s engine that's the same bore and stroke. Every time.
    If you want reliable Honda power, a 10:25:1 X engine is my favorite. Obviously this requires a new piston.
    Apr 2010
    Indian Falls, NY
    1,289
    Speaking of the 10.25:1 engine, the stock motor was rated 18hp at the crank. What do you think the higher compression piston and overbore would yield? 1-2hp? Now that you've brought it up, I'm curious for that special build.
    Mar 2013
    Morristown, TN
    25
    I personally have been thinking about doing a crazy swap like a 300 or 400ex motor. Has anyone ever done that?
    Apr 2010
    Indian Falls, NY
    1,289
    That would be interesting but I don't know if it would fit. Sprocket alignment would worry me as well.
    Oct 2013
    Wherever I May Roam
    3,757
    Slashfan yes more than likely you are in the ball bark, maybe 3. Results vary with tuning and it all depends on the parts you combine to take advantage of the extra compression. Obviously there are not many dyno results from trikes, especially not mild built, to compare.
    Curtie, in my opinion neither of those engines are worth the trouble to swap.
    The word 'crazy' is relative, and neither of those engines fit my definition.
    If you want a sport trike with a 300cc plus engine Honda already built one better than you can. Its called a 350x.
