Results 1 to 10 of 10
Thread: 85 250r exhaust o-ring
    Carthage NY 250r rules
    2,355
    My 85 250r was missing the exhaust flange sealing ring .Iv looked for them couldnt find anything and silicone only last so long.I was given a stock banshee headpipe last year.I didnt know they used o-rings on them till I was cutting it up to use a section for my 84 200x when I noticed the o-ring.I used the o-ring on my stock 85 flange.I had to pry the headpipe on but it doesnt leak.
    250r rules
    Slidell, LA
    4,738
    not a cheap fix by any means and I am sure you already did this, but in case you didn't ESR and Duncan still offer the two o-ring setup. I am migrating to this soon because I am tired of my 3rd gen splooging everywhere
    Duncan: http://www.duncanracing.com/mm5/merc...tegory_Code=32
    ESR: http://www.eddie-sanders-racing.com/...t%20flange.htm
    2,355
    I read over on trx250r site that you can use bdt silicone o-rings on the stock flange.Carlos said to put one in the stock groove and another on the front tapper section.He also said there is a tripple setup .
    250r rules
    Mar 2014
    galt, ca
    94
    Soooo, the IPC shows a metal split ring, and, what I just picked up, a dark grey, semi metalic looking o-ring. Cheap Cycle Parts has them in stock. I there is something significantly better.... I would be interested for the future.
    devore,ca
    1,024
    Stock ones were metal rings. The looked like a piston ring. The aftermarket flanges use O rings. They work better and aren't all that expensive.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Mar 2014
    galt, ca
    94
    Quote Originally Posted by badandy View Post
    I'll restate this for anybody who cares... See below... there is a seal, metalic and flexible, yet not quite an o-ring as well as a metal split ring (which does look like a piston ring)
    7
    GASKET, EX. PIPE
    18352-HA2-010
    $4.33
    8
    RING, EX.
    18358-HA2-000
    $8.16
    2,355
    I put the o-ring where the split ring goes. I broke my oem split ring years ago and I replaced it with a chainsaw piston ring it was the exact same size.That broke when I switched motors a few years ago .When I contacted my local Honda Dealer they said it was discontinued. The banshee o-ring seals realy good. Im thinking of ordering a set of silicone o-rings from Carlos at BTD I think you can get a multiple pack for a good deal.I am going to get some new Banshee o-rings to try on my aircooled 250rs.
    250r rules
    Blossvale NY
    4,563
    I have an ESR O-ring type flange on one R and a BDT O-ring flange on the other. Both work very well and spooge is minimal at most. Not overly expensive and well worth it IMHO, especially if you are using a nice pipe that you want to stay nice. If your pipe/flange fit is loose it's going to wear on both from the vibration.
    But it sounds like your setup is tight from your initial post...
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    2,355
    BDT 4 o-ring flange.for atc/trx 250r and big bore .Click image for larger version.
ID:	191882 Click image for larger version.
    250r rules
    Mar 2014
    galt, ca
    94
    Spend what you want.. my "o-ring" gasket, cost $4, stock part, new, accompanied by the also stock split ring...
    Of course there are options....
