Results 1 to 7 of 7
Thread: Tire question!!!!!!!!!!!!!
    Apr 2014
    Eastern Pa
    22
    Can I replace my 25x12-9 tires on my 83 Honda 200, with 22x11-9 tires?
    Who has done this before?
    And can I see pictures?
    I would just like a little better handling and rear wheel well space under the fender.
    Thanks!
    83 Honda 200
    85 HondaTRX 125
    85 Honda70
    Mar 2014
    West Texas
    16
    It'll fit. Do it to it!!!
    Sarnia, Ontario, Canada
    3,415
    The 83 Big Red 200 was the only ATC200 with 25" tires..all the rest had 22x11x8.
    Essentially the same trike..the only difference between was the chain sprocket gearing.
    So for you to swap to a smaller tire is fine..with the higher ration sprockets meant for bigger tires you will lose a bit of top end speed, but gain some power.
    It will basically look like the ATC200s..
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Michigan UP
    1,005
    I've owned two 1983 atc200 that weren't big reds and both had original tires that were 25x12x9. They were just the plain 200, not an E, or S.
    Apr 2014
    Eastern Pa
    22
    Yeah...Mine is not a Big Red. Either........So ill look into the 22x11-9
    any other opinions?
    Thanks
    83 Honda 200
    85 HondaTRX 125
    85 Honda70
    3,415
    Quote Originally Posted by SteelHorse View Post
    any other opinions?
    Thanks
    You could swap the rear hubs..I've been told the 84-85 200x hubs are a direct bolt on and they change the bolt pattern to a much more common 4/110. This really opens up rim/tire choices for the rear at least.
    The front hub is a no go..no direct fit swaps that I have been able to find.
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
    Oct 2013
    Wherever I May Roam
    3,757
    I can confirm that the 83-85 200x hubs will work. They are available as new repros too. Nice looking,
