Results 1 to 7 of 7
Thread: 200X motor bogs when wheelied??
    Oct 2008
    Reedsport Oregon
    856
    ive got my trike super dialed in, its FAST! outruns a stock 350x, but it bogs if i wheelie it for awhile? sounds like its either flooding or running out of gas? it has a DG carb on it, dynojet jets. runs great everywhere else but when wheelied?
    any easy fixes?
    float wrong? is it even adjustable?
    Apr 2010
    Indian Falls, NY
    1,289
    Sounds like it's not getting fuel if you keep it up for a while. The carb was not meant to supply fuel going "up" against gravity so that could be doing it.
    Though I have known people to ride long wheelies but if they are ridiculous, then I can see it potentially causing an issue.
    Otherwise I'm not sure.
    Oct 2008
    Reedsport Oregon
    856
    the stock carb could wheelie for miles, my 82 r went for miles, its gotta be the float i guess? ive never had this problem before other than on a streetbike
    Oct 2008
    Reedsport Oregon
    856
    update: i adjusted the float, it didnt help it still conks out in a 1st gear vertical wheelie. my buddies 200s i ride will not do this in a vertical wheelie, im lost here?? my bike is extremely hard to start after i wheelie it so its either running out of gas or flooding, doesnt backfire so im guessing runs out the overflow tube as its wet and so is the pavement where i wheelied, any input?
    Oct 2013
    Wherever I May Roam
    3,757
    I would suspect gas level as well, but gravity and vacuum sometimes just don't play well together. Maybe try another carb just for comparison.
    What carb do you have? Nevermind I just read its a dg carb. Never seen one.
    Oct 2008
    Reedsport Oregon
    856
    should i route the overflow tube elsewhere? its kind of my last option.
    Carthage NY 250r rules
    2,355
    Does it flood out or run out of gas. If its flooding out check your over flow vent make sure they arent clogged.
    250r rules
