Results 1 to 11 of 11
Thread: 185 weighs 30 pounds more than the 185s, not sure why
    JustEnough's Avatar
    JustEnough is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2009
    Elk Grove, CA
    334
    Anyone know how they made the 185s 30 pounds lighter than the 185?
    The specs look the same:
    http://www.3wheelerworld.com/content...Technical-Data
    6,813
    Very simple lol the plain 185 is a bigger machine than a 185s .
    Oct 2013
    Wherever I May Roam
    3,757
    25 inch tires as opposed to 22 inch. Bet that's most of it right there.
    Mar 2013
    hesperia
    68
    maybe the luggage racks & tires
    Afrothunderkat's Avatar
    Afrothunderkat is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2011
    Richmond NH
    336
    The S stands for "beefcake" bro
    2003 RM 250 ::: 1985 ATC 250R ::: 1986 ATC 250ES
    Past Trikes: 1985 YTM 225DX ::: 1984 200s ::: 1985 YTM200
    Past Bikes: 1987 KX80BW ::: 2002 TT-R 125L ::: 2000 RM 125
    Quote Originally Posted by Tri-ZNate View Post
    Talking about the build quality, I got their exhaust and economy muffler and it fits together like tossing a hot dog down a hall way with nothing provided to take up the slop. Best $200 ever spent
    Jun 2009
    Leander TX
    2,217
    Baltimore, MD
    6,088
    Honda was young and still learning. The 185 was considered a work horse and the 185s more of a sporty machine as well.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Tionesta, PA
    5,747
    You should see the 185 bare frame VS the 185S bare frame. About 6 or 7 pounds there I bet.
    JustEnough's Avatar
    Oct 2009
    Elk Grove, CA
    334
    I wonder if the 185 frame is any stronger? My guess is that the 185s frame is a better design and does not sacrifice strength. The 185 has split rear fenders, so maybe the frame design for that makes it heavier.
    I have a friend that is looking for an ATC for rock crawling and he was looking at late model 110's and 125's. I finally steered him towards the 185s because it has a lot more power, the frame is stronger and it does not weigh much more.
    I was clear on why the electric start models weigh more.
    I totally missed the wheel size, thanks to all for the input.
    Oct 2013
    Wherever I May Roam
    3,757
    If your buddy wants ant ATC for rock crawling I would suggest a jeep instead
    But if you mean to take with when he goes rock crawling, I'd get a suspended bike.
    Dec 2005
    South Carolina
    61
    Assuming that we all are referring to the 1980 Honda ATC 185 it does weigh more than the 185s. A good friend of mine who got me back into three wheeling commonly refers to it (1980 Honda ATC 185) as the "big frame" 185. As someone has already said in this thread, Honda was still in the development stage and figuring things out. The next year in 81' you saw the smaller 185s from 81' to 83' and the 83' 185s having front fork shocks which then morphed into the 84' 200s. Also to be noted is that the " 80' big frame 185" morphed into the 81' 200 with fenders trunks grab bars etc, interchangeable between them and the other ATC 200 thru the 1983 ATC 200 baring the front fork shocks that year.
