Thread: New TRX70 and questions
    Tomcall's Avatar
    Tomcall is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2010
    Arizona
    215
    Just picked up this 86 trx70 today. New project for me. Can anyone tell me if the 73 and 74 atc70 engine parts are interchangeable with the trx70?
    Thanks
    Attached Thumbnails Attached Thumbnails IMG_7133.JPG   IMG_7132.JPG   IMG_7129.JPG   IMG_7127.JPG   IMG_7126.JPG
    Jun 2009
    Leander TX
    2,217
    Yes - all ATC 70 engines will bolt in.
    You'll need the ATC coil too.
    The TRX engines use CDI instead of points.
    Tomcall's Avatar
    Nov 2010
    Arizona
    215
    Thanks jb2wheels
    I was needing to know if the engine parts are interchangeable. I have a number of parts for a 73/74 atc70 motor. Are the internal parts identical to swap out if I have a part in better condition from my 73/74 atc70 parts?
    Jun 2009
    Leander TX
    2,217
    Ah - got it!
    Crank is different due to CDI flywheel and such.
    TRX has a 4 speed instead of 3.
    Top ends should swap.
    I put an 88 kit from DRATV on my 86 TRX. As I recall, it was listed for all ATC/TRX 70s.
    Tomcall's Avatar
    Nov 2010
    Arizona
    215
    Thats helps. I was thinking the bottom end was likely different. I refreshed the clutch and it looks identical to the other atc's.
