Results 1 to 15 of 25
Thread: 86'T3 pipe
    tecaterob is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2008
    Miami Fl
    435
    86'T3 pipe
    I looking to see what's out there for pipes. I only some DG and Stock pipes.
    3 86 Tecate 3
    1 87 tecate 3 (with kx 540 motor)
    1 87 tecate 4 (with 330 motor, 250r geometry)
    1 83 atc 70
    1 Kfx 50
    1 kfx 400 ( with 470 parting out bike)
    1 78 KZ 1000 ( with 1340 turbo)
    1 Aprilia SXV 550 Supermoto
    1 01 ZRX 1200 prostreet (sold)
    East Central Illinois
    677
    Are you looking to buy a used one or to find out who makes new ones? JEMCO makes new ones, and I believe LRD has made a couple but those may have been one-offs. BDT will make you one and it will be beautiful but major $$$$$.
    nstyle73
    "When in doubt, wind it out"
    Feedback: http://www.3wheelerworld.com/showthr...k-for-nstyle73
    Jul 2012
    Seattle, Washington
    1,543
    I know NWrider was selling alot of parts for the 86 t3. When I bought some parts from him he did have several pipes too, Awnser, Jemco, FMF and a few others.... Send him a PM but be prepaired to open your wallet the 86 parts can get spendy.
    http://www.3wheelerworld.com/showthr...rts-101-photos
    Oct 2008
    Miami Fl
    435
    I've emailed Jemco but never get response. I looking for the pipe I can get the most power. LRD stay makes pipes for them?
    3 86 Tecate 3
    1 83 atc 70
    1 Kfx 50
    Jul 2012
    Seattle, Washington
    1,543
    LED makes pipes too: http://www.3wheelerworld.com/showthr...986-Tecate-WOW!
    Theres a white brothers on ebay right now too.
    Oct 2008
    Miami Fl
    435
    I sent them an email today.
    I saw the white brothers on eBay, but looks in bad shape. Everything on my bike is new.
    3 86 Tecate 3
    1 83 atc 70
    1 Kfx 50
    Sep 2005
    MICHIGAN
    2,027
    I had a Pro Circuit pipe for 86 KX250 on mine and couldnt tell the difference from the DG pipe that is back on it.
    86 T3
    84 T3
    86 KX250
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by tecaterob View Post
    Howdy!
    Just curious, what do you mean by "the most power". Pipes are designed to make peak/max power in different rpm ranges.
    1. TRAIL PIPE = Bottom end power.
    2. MX PIPE = Mid range power.
    3. ROAD RACE PIPE = Top end power.
    These pipes should also be matched to the porting style of the cylinder. A custom pipe might best serve your needs.
    If you want something temporary until you get a pipe and you are running the stock silencer, you can simply remove it and install a straight through one if you don't need a spark arrestor. It will run much better. We spent a ton of time test riding and dyno testing several different pipes for the 86 model and I can assure you that you may install an aftermarket pipe and not be as happy with it as the stock pipe. Different is not always better.
    It’s kinda hard to make a Tecate or ANY Honda run much better than this.
    The KAWASAKI Tecate…the most power and fastest 3 wheeler in the universe!
    Holy cr_p that roost is ridiculous!
    Oct 2008
    Miami Fl
    435
    Looking a mid-top end pipe. It's has a big bore so I have some bottom.
    3 86 Tecate 3
    1 83 atc 70
    1 Kfx 50
    Jan 2013
    minnesota
    5,911
    Howdy!
    Ok, call me stupid, how did you put a big bore on an aluminum nikasil cylinder with a power valve?
    Ok Barn...you're stupid!
    What size is it?
    You are likely better off with a custom pipe because the existing aftermarket pipes are designed for 250 cc's. They will work on it but will not be the best match. Even custom pipes are rarely ideal unless they build then test several variations to find the best one.
    At Kawi, it finally came down to two two different pipes. one was the current, mid range pipe and the other was more of a top end pipe and the dyno showed more hp with the top end pipe so all the engineers figured that is the one i would pick. Well when they were actually tested in the dirt and not on the dyno, the current y3 pipe performed better overall so that is what i went with. the other pipe did have more top end and peak rpm but the power deliver was not as smooth and had less mid and was more like a light switch.
    I also tested pipes for my friends Harry Klemm and Dave Miller aka DG and FMF, and they too gave me more than just one style to test.
    I guess what I'm getting at or trying to say is that even if you spend $600.00 on a custom pipe, it might not be as good as it possibly can and you might be disappointed. It's really kinda of a bummer but pipes definitely are rocket science and it takes some trial and error to get it right but unfortunately, that is done with your money, not the pipe builders, lol.
    None of the aftermarket pipes I'm aware of are geared towards producing many more peak rpm's so they might not fit your bill anyway.
    Also, there is another thing that few people are aware of which doesn't really apply to you, it's just some trivia. Those bikes have rev limiters, and the bike in stock form, will hit it if you try hard. Well there are several people that put on these fancy high hp pipes and do all this whazoo porting and lock the power valves open and say it has so much more top end rpm. Well it doesn't because they still never hit the rev limiter.
    O.C., Oregon
    921
    +10 for LED custom pipes. Mine is built for Mid to Top to complement my motor he built for me. Arlan does awesome work.
    1978 ATC70 w/ Piranha 140cc
    2017 YZ 250x- Braap
    677
    You will have to call JEMCO if you want to talk to John. I believe the "White Brothers" on ebay is a white brothers silencer and a ??? headpipe.
    nstyle73
    Oct 2008
    Miami Fl
    435
    I spoke to LED today. They would need my bike there and its crazy $ for them to do it. I'm not going with that idea.
    3 86 Tecate 3
    1 83 atc 70
    1 Kfx 50
    Jan 2013
    minnesota
    5,911
    lol, how much is it?
    O.C., Oregon
    921
    My 250r pipe was in the $450 range with triple plate chrome. Not bad for a custom handmade pipe IMO..
    2017 YZ 250x- Braap
