Results 1 to 13 of 13
Thread: Best mud tires for atc 110?
    Apr 2014
    AR
    25
    What mud tires should I get for my atc 110? I'm getting new rims also. What kind should I get? Aluminum or steel?
    Feb 2013
    arkansas
    136
    Idk about rims but get something that's wide and will float. The air box is very close to the rear axle so don't take it to deep! I would try to find some wooly boogers or rawhides I used to have a set of both I wish I still had. But for a more modern all out mud tire they make 26 outlaws I think or dirt devels or mud wolfs. U want something that will clean out.
    I didn't want to shoot that man but he heard that I was fast you know hat liqueur gave him the courage that put him in the ground
    Why Ike, whatever do you mean? Maybe poker's just not your game Ike. I know! Let's have a spelling contest!
    Oct 2013
    Rittman
    30
    ITP Mudlites
    1984 200x
    2007 Recon 250
    NEPA
    7,051
    Buckshot mudders. Will also turn it into a snowmobile
    Jan 2013
    minnesota
    5,911
    Howdy!
    RIMS – Unless you think you might bang them up, aluminum are fine and a bit lighter than steel.
    TIRES - Well, your factory tire size is 16x8x7. The only tire specifically for heavy/deep mud I could find is the one below. It is also a 2 ply like the factory tires so it will bog your bike down a little less than a 6 ply and will have a slightly softer ride than a 6 ply if that matters at all. Two plies are slightly more susceptible to punctures than 4 and 6 ply but there are few choices in your size. Plus they're dirt cheap, only $36.00 each. The 9314 are rear and 9313 are fronts [but confirm with seller] AND they are made by Cheng Shin which is a very good tire mfg..
    See prices here.
    http://www.bikebandit.com/cst-c9313-...FaYF7AodKlYACg
    Dirt cheap...
    Jun 2009
    Leander TX
    2,217
    That is dirt cheap for a 70 tire.
    Apr 2014
    AR
    25
    The tire size I have is 22x11x8 so it's not those barnett. I'm trying to choose between kenda bear claws that are 22x12x8 it gbc gators that are 22x11x8.
    They are 8x 8 inch rims and the pattern is 4/130.
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by Gwatson212 View Post
    Holy cr_p, are riding in mud or quick sand, lol. It's better to run a wider rim on those tires but your not goin fast so not a big deal.
    Apr 2014
    AR
    25
    I'm riding in mud. And some trails.
    Apr 2014
    AR
    25
    Where would I get wider rims that are still 8 inches and have the 4/130 thread pattern. I have an aftermarket dg exhaust and I'm afraid that the new wider rims and tires will rub the exhaust.
    Jan 2013
    minnesota
    5,911
    hi
    here's 8.5" wide with 3.5" backspace, so it hopefully will not move it in towards the inside anymore than it already is but you need to measure the backspace on your current rims.
    https://www.denniskirk.com/ams/large...prd/551047.sku
    Apr 2014
    AR
    25
    The backspace ok the ones I have is 3inches
    May 2013
    Zachary, Louisiana
    13
    The max tire size for a 110 is 26in. I personally have had great success with interco tsl/atv super swampers
