Results 1 to 9 of 9
Thread: '85 250sx carb spewing fuel...
    Mar 2012
    Glen Rock, PA
    551
    Hello, the other day my SX started spewing fuel out of the top and bottom drain tube and became VERY hard to start.
    Does the carb need a rebuild? If so, how hard is it to do and is there anything I should know?
    Thanks.
    Ragin' full on...
    Jan 2011
    Choctaw, OK
    2,755
    Here is everything you need to know.
    http://www.3wheelerworld.com/showthr...54#post1257154
    Oct 2013
    Wherever I May Roam
    3,757
    More than likely the float needle is stuck open.
    This is commonly cured by tapping the bowl with the end of a plastic screwdriver, or simply riding it hard to dislodge the float needle, but its always a good idea to check it all out as flyingw suggests. There could be junk in the carb holding the needle away from the seat as well.
    Usually a major fuel leak doesnt indicate the need for new carb parts, things like that tend to slowly get worse over time as opposed to a sudden leak.
    Mar 2012
    Glen Rock, PA
    551
    Thanks guys! I suppose the first thing I'll try is a thorough cleaning. Now that I think about it, before this happened I pulled the filter/stopcock from the tank to clean it and a bunch of crud fell out. Maybe some of that junk got into the carb and caused the float to stick. I tried the tapping and hard riding to no avail when it all started.
    Ragin' full on...
    Mar 2012
    Glen Rock, PA
    551
    And FlyingW, great post on those carbs!
    Ragin' full on...
    Jan 2011
    Choctaw, OK
    2,755
    You're welcome. I've had all good feedback on my tutorial. It really doesn't take much to keep the float valve from seating. In fact a human hair across the seat will keep it from seating. Give it a good cleaning and a fresh rebuild kit.
    Sarnia, Ontario, Canada
    3,415
    So what you're saying Jim is we best wear a hairnet while doing a carb rebuild??
    I didn't see that in your tutorial!
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Jan 2011
    Choctaw, OK
    2,755
    I'd suggest a full body condom!!!!!!
    Maine
    463
    Any luck with carb cleaning?
    Current Trikes
    2 1985 Honda 250sx
    1985 Big Red
    2 1983 YTM 200k's. 1 for parts.
    KLT 250 Prairie
    1982 Honda 185 - Waiting to be saved
    1985 125m Parts Machine
    Still on the hunt for a 1986 350x and 250r.
