I can't find new bushings for the rear caliper torque link does anyone know what the dimensions are for them or a way to get something to work I am stuck and I'm almost done with my rebuild thanks
I have torque link bushings but I'm not sure if they are R or X. I need a torque link in my hand to make sure. I probably have both but no way to confirm.
Here's the large ones I have. The ones on the left have a 12mm hole and the one on the right has a 10mm hole. The small on may be a bit trickier. I need to see an example. I know its just a barrel but I think it has an 8mm hole. All dimensions are in MMs.
The ones on the left I'm pretty sure are for the 85 250R torque link. The one on the right is 1mm larger than the others. Do you have some micrometers to measure the ID of your torque link?
