Thread: 350x rear shock adj.
    350xorbust is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2013
    Dryden ON
    196
    My 85 350x rear shock's rebound is set too stiff. Which knob is for rebound and how do i adjust the rebound so it isnt trying to eject me off the bike?
    Jan 2013
    minnesota
    5,911
    Hi;
    Quote Originally Posted by 350xorbust View Post
    turn the knob on the shock body, [not the reservoir] to a lower number to reduce the rebound damping.
    if your shock is not "packing down" over consecutive bumps, turn the knob on the shock body, [not the reservoir] to a higher number to increase the rebound damping.
    1,641
    More than likel your 29 year shock could use a rebuild.The gas is more than likely gone.You won't see too much help with adjusting anything.The spring is doing all the work.Having a shock redone is usually covered under a rebuild.It isn't very exspensive unless the shaft is bent.Your front forks should be service also.Then again with the monster tires you won't notice much improvement.Whatever you didn't rebuild or replace will fail once you start riding it.So you should start replacing those items now.
    Feb 2013
    Dryden ON
    196
    Thanx Barnett I will give that a try.
    Feb 2013
    Dryden ON
    196
    Hey Barnett that did the trick...thanx
    Feb 2013
    Dryden ON
    196
    Quote Originally Posted by jays375 View Post
    Hey Jays...please refrain from commenting on my threads. Your coments are neither wanted nor needed. If you continue doing so you leave me no other choice but to go to the moderators .
