Yamaha Tri Moto 125 no fuel
I have a yamaha tri moto 125 and I cannot get it to stay running. I pulled this wheeler out of a tree belt and cleaned the carb. I hooked the carb back up and it will start with starting fluid but will not stay running. It seems like it is not getting fuel. I premixed the gas because I didn't know if the 2 cycle pump was working. Should I reclean the carb or Is there something something else I can do to fix this?
I'm no 2 stroke expert but you should probably clean out the carb again, get rid of that premix, put fresh gas in, make sure the oil injector thing is filled and try from there. Premixing on top of the injector is probably making it way to rich to run.
When I got mine, it seemed to do the same. Unscrew the petcock from the gas tank & have a look at the two filters there, mine were trash. I didn't source replacements, I simply put in an inline filter that I can see when gets dirty.
//ArrowChat Integreation Code
