Results 1 to 12 of 12
Thread: Honda ATC CHAMPION Spark Plug Part Numbers#
    Winnipeg
    211
    Honda ATC CHAMPION & NGK Spark Plug Part Numbers#
    Attached Thumbnails Attached Thumbnails Honda ATC Spark Plug.pdf
    Winnipeg
    211
    CHAMPION to NKG Convertor
    Please don't run Champions anyone..............
    Jan 2014
    La
    1,062
    Dont run champisn plugs always run nkg.
    Oct 2008
    NB, Canada
    852
    I always use Champion plugs, I find they resist fouling better, and when they do foul, you can clean them and get a bit more life out of them.
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    Always Hoping For a Maritime Trikefest- http://www.3wheelerworld.com/showthr...s-where-you-at
    "Wear Limits Are Just A Suggestion"
    Winnipeg
    211
    I haven't had any issues with champion.. but I did put the champion to NGK converter part number in the second post
    Mexico
    9,014
    I think my lawnmower came with a Champion plug, but aside from that I can’t think of any device I have that I dislike enough to put one in.
    May 2009
    S.E. Michigan
    1,251
    I have personally witnessed three occasions (not my car) where a champion plug was attempted to be removed from an aluminum head and the hex portion that engages the socket snaps off and leaves the threaded portion in the head. So, in your hand is an insulator and half of the spark plug, and in the head is a threaded sleeve with absolutely no easy way to get it out.
    I DO NOT run Champions anymore (and I run a small dab of anti-sieze on my NGK's too!)
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Winnipeg
    211
    bump bump bump
    Mar 2007
    Texas
    5,045
    Stick with NGK. Want better quality and so many more options. From iridium to copper and then to different racing styles.
    ________________
    https://www.mikesatvfix.com
    Apr 2012
    USA
    4,133
    This is from an automotive background, but whatever the engine came with FACTORY is what you put back into it. Now if Honda's service manual says you can run Champions, then do it if you want, but personally I stick to NGK or Denso for Jap built engines.
    Mar 2007
    Texas
    5,045
    you guys have to understand back in the day NGK was hard to find or get and so Champion was the most abundant. Thus Honda made the US manuals to say use Champion and used those as well only because of current supply at the time. Fast forward 30 years and you will never ever see a factory new Japanese machine running champion from the factory. NGKs are now plentiful and even more abundant than champion stuff. Role reversal for sure. the good thing is they are so much better quality too!
    ________________
