Thread: 85 250r rear suspension adjustment
    dream3wheeler is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2010
    International Falls MN
    362
    Normally ive never had any trouble adjusting suspension, but for this one its different. The nut is stuck and wont spin, tried spinning it both ways but that thing isn't giving. At this point ive got cuts all up and down my arms and fingers from the wrench breaking loose. Its been sitting over night with wd40 on it. before I go back out there and keep cutting myself, does anyone have any tips?
    Oct 2013
    Wherever I May Roam
    3,757
    Some of them require a using a and a flat blade driver to get them unlocked. Maybe you could consider some gloves?
    Billy Golightly's Avatar
    Live Oak, FL
    15,070
    Your talking about the preload nuts on the top of the spring? Are you using a spanner wrench, or what are you trying to get on them with? If they've been unfortunate enough to get a and punch often the spanner wont fit anymore and you might be reduced the channel locks...
    Jun 2009
    Leander TX
    2,217
    I have no luck adjusting preload with the shock on the trike. I take them off and use some big old ugly tools to get the rings moving.
    Aug 2010
    362
    Ive got a shock spanner wrench that I used first. but not matter where I hooked the darn thing itd still slip and I couldn't get enough leverage to free the nut. I have also tried a and punch but that only started to damage things, also tried vice grip pliers, those seem to hold better than anything but still not enough to free that nut.
    Aug 2010
    362
    well good news, I got it all loosened up and it finally broke loose. but im curious now, is there a spec for how far the back end should lower with no load applied to the shock? because it seems that under the machines own weight the back end lowers about an inch or more, im no suspension expert but shouldn't the shock at least be able to hold up its own weight?
