Results 1 to 7 of 7
Thread: 1984 200es wont start
    King Trikester is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2013
    Canada, B.C, FSJ
    435
    I traded a few things for this machine, its clean, i was told it ran but had an air leak.
    I changed the cracked air intake and it fired right up, but it must have had another air leak and went into a "death rev" as soon as it started, it reved really high so i hit the killswitch right away. I took the carb out and replaced every o-ring on the intakes/carb and am confident there wont be anymore air leaks. Now it wont start, it has spark and it is getting fuel, any idea of what I might have done, or where to start?
    to be clear, it has a nice bright blue spark, and the spark plug is wet with fuel after tuning it over
    shovelryder's Avatar
    shovelryder is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2012
    Buffalo, MN
    427
    It sounds like its not getting air???? The death rev shouldnt happen in a 4 stroke unless the slides stuck in the carb? Ive never heard of a 4 revving like a 2 stroke due to and intake or case leak.
    cap's Avatar
    cap is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2014
    Nevada
    163
    It will rev like that if you forget to put the slide back in and start it, a massive air leak.
    You need to go back to basics, prime the carb with a squirt of starting fluid, if it fires off then it's not getting fuel through the carb. Pull it apart again and check the float/needle. Sometimes you can rap on the side of the carb to unstick the float needle without removing it.
    Sep 2013
    Canada, B.C, FSJ
    435
    Ok I might have exaggerated a little bit, it revved up like wide open throttle, the carb was cleaned by the P.O so maybe they did something wrong? I'm pretty confident that it's getting fuel, I tried the old starting fluid and it still won't fire up, almost like the timing jumped out of place if that's even possible, I haven't had a whole lot of time to tinker with it but I get the next few days off
    Baltimore, MD
    6,088
    Make sure the carb slide is properly installed the throttle cable isn't stuck for starters.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Sep 2013
    Canada, B.C, FSJ
    435
    i did pull it out and inspect it, it functions properly and is installed proplery, it only goes in one way, at least i hope so. the thing i did notice was it was very loosly in place, so i put in a new oring on the top of it, i do belive this is where the air was coming from. But still no igniton, it has tones of compression, i need to use the decompression leaver and the old lady cant even pull it over, unlike my last one i had, I called her old smokey
    cap's Avatar
    Jan 2014
    Nevada
    163
    Its very unlikely the timing jumped, but easy to check if you pull the CDI cover and the timing mark cover.
    More likely you have a messed up carb.
