I've used an e-bay carb before. I can't remember which of the many "brands" or sellers it was, but it worked. It was pretty good. I'm not sure if you can use the standard rebuild kits for them when the time comes. They are so cheap that pretty much I think they are disposable. If you manage to wear one out to the point of needing a rebuild, then you can just buy another.
Are you sure you can't get the idle screw to adjust it? All it does is hold the slide a little bit more open. Sometimes, if the surface on the slide that the screw pushed on is really gnarled up, you can open the throttle a bit with the thumb throttle, adjust the screw in, and then let go. You should be able to get it to go.
- Frank
1984 200ES Big Red
1985 350X (x2)
1986 350X
1986 250SX
1984 Auto-X
1984 ATC70
1985 ATC70
