Results 1 to 3 of 3
Thread: yt reeds
    Jan 2011
    smithton missouri
    96
    yt reeds
    I got my reeds in today for my 82 125 Yamaha I went to install but the holes are to far apart on the new reeds the number was 603 boyesen so is my cage or motor an 83 and how do I tell without ordering more for an 83?
    Nov 2008
    Coon Rapids, MN
    956
    whats the vin on the motor?
    1980 - 1984 have a 9 digit serial number for the engine/frame. They will match, unless someone has changed the engine. VIN decoders will not work.
    1985~ - 9 digit on engine, 15 digit on frame. You can use a VIN decoder to figure out the year, such as this.
    http://www.motoverse.com/tools/vin/yamaha.asp
    If someone knows a better VIN decoder (without CAPTCHA), post it up.
    I included the 1985~ numbers, in case you want to check and see if you have the correct year engine, in your machine (works on most models).
    1EV-000101-on______1985 YTM225DRN__(15 digit on frame)
    1NV-000101-on______1986 YTM225DRS__(15 digit on frame)
    1RX-??????__________1986 YTZ250S____(15 digit on frame)
    20E-??????__________1983 YT175K
    21V-000101-100100__1983 YTM200K
    21V-100101-160100__1984 YTM200L
    21V-160101-on______1985 YTM200N____(15 digit on frame)
    21Y-??????__________1983 YT125K_____(See note below)
    21Y-??????__________1984 YT125L_____(See note below)
    21Y-??????__________1985 YT125N_____(15 digit on frame, see note below)
    24W-000101-100100__1983 YTM200EK
    24W-100101-on______1984 YTM200EL
    29U-000101-060100__1983 YTM225DXK
    29U-060101-on______1984 YTM225DXL
    29U-100101-on______1985 YTM225DXN__(15 digit on frame)
    2FW-??????_________1987 YTM225DRT__(15 digit on frame)
    36R-??????__________1984 YT60L
    36R-??????__________1985 YT60N______(15 digit on frame)
    38W-??????_________1985 YTZ250N____(15 digit on frame)
    3X3-??????__________1980 YT125G
    4U3-??????__________1981 YT125H
    52G-000101-on______1985 YTM200ERN__(15 digit on frame)
    5V6-??????__________1982 YT125J
    5V7-??????__________1982 YT175J
    As far the manuals list, 83,84,85 YT125's, all start with 21Y. The 85 has a 15 digit VIN. None of the manuals I have, show a cut off serial number between the 83 and 84 models. I use the decals (if possible) to tell the year. If someone has a 83 or 84 YT125 and it's starts with something other than 21Y, knows another/better way or if I made an error in this list,
    1982 Yamaha YT125 tri-moto - Boyesen power reeds, YT175 front suspension, Headlight guard.
    1982 Yamaha YT175 tri-moto - Running but ugly
    1984 Yamaha YT 60 tri-zinger - Boyesen power reeds
    My feedback.
    http://www.3wheelerworld.com/showthr...ght=old-yellow
    My album
    http://www.3wheelerworld.com/album.php?albumid=98
    Wichita, Kansas
    1,361
    I dont trust vins on the motors when it comes to matching reeds. There is basically 2 reed cage for these motors. The early and the late model. My 1980 125 had the late model. The cages interchange but the petals do not. If you have an address i can send you a set of reeds.
