Results 1 to 15 of 49
Thread: Best Tires for a 250SX
    GSUwhiskers's Avatar
    GSUwhiskers is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2014
    Georgia
    168
    My rear tires are dry rotted, and the tread on all three tires looks rough. I was wondering what you guys recommend as far as tire brand. Also do ya'll just run stock tire sizes, or go wider/slimmer etc..
    Also where do ya'll usually buy your tires from? Online?
    May 2014
    Georgia
    168
    I forgot to mention I'm trying to make this ride a little mudding machine, not just the average cruiser.
    Jul 2011
    Eau Claire, WI
    1,188
    Kenda Bear Claws.
    86 Honda ATC 200X Frankentrike (Project)
    80 Honda CB650C Conversion (Project)
    3WW Feeback Thread For DasUberKraut
    Retired Machines - 02 Honda TRX 300EX, 85 Honda ATC 250SX, 84 Honda ATC 200X Astro Kit, 85 Honda ATC 70, 85 Honda ATC 200 Auto-X, 83 Honda ATC 200E Big Red, 84 Honda ATC 125M (X2), 82 Honda ATC200, 81 Honda ATC 185S, 81 Honda XR250R
    Jan 2011
    Choctaw, OK
    2,755
    For a muddin machine, I agree with DasUberKraut. Bear Claws rock!!!! Option B would be Mud Lites.
    May 2014
    Georgia
    168
    Okay great, my second question is I don't see bear claws made in the stock 22x11x8, so will 22x12x8 fit the stock rims on this wheeler?
    Jan 2011
    Choctaw, OK
    2,755
    yes but not for the front. Stick to a knobby style tire for the front if you're buying a front.
    May 2013
    St. Louis
    505
    Quote Originally Posted by Flyingw View Post
    I just want to add that all the knobbies are not the same . The size listing will be the same , but some are to wide and they rub when they flex while riding .
    I bought a knobby from Flyingw thats perfect . I can get the make if needed .
    Sarnia, Ontario, Canada
    3,415
    I'm agreeing with every word so far..but as a guy who makes it his hobby to experiment with new tire/rim setups hear this!!
    New front plan for you..
    Rim: 4/110 ITP Steel Wheel 10x5 2.0 + 3.0
    Tire: Kenda Bear Claw ATV Tire 23x7-10
    It's inexpensive, a direct bolt on without the need to shim, and will improve the handling incredibly!!
    Oh yeah, it looks pretty bad aZZ also without the need to do a frontend swap like some of the guys have done!!
Name:	full trike.jpg
ID:	195143Click image for larger version.
    Rocky Mountain ATV is my favourite tire supplier online(or others) and should be able to fix you up..the front tire and rim will run around $100 from most vendors.
    One more thing..mount the front tire as a 'right side' to get the directional tread pointed in the right direction. But truth is it doesn't matter..I've got it backward on my 250ES and it's all the same!!
    Good luck..
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Jul 2011
    Eau Claire, WI
    1,188
    Hey Doug... Doug here. Ha ha!
    That Claw on the front is sexy! I was almost thinking Kenda Front Max. I have that style on my Auto-X. I may end up with a 3rd Claw now. Have you experimented with a Front Max style at all? Just curious if it makes a difference from a smaller 200 cc to the 250's with almost 100 lbs more dry weight.
    3,415
    Quote Originally Posted by DasUberKraut View Post
    Yeah Doug, I have a Kenda Front Max on my 350X and it's great on the trails/sand/fields..but no never on a smaller machine. Don't know what to tell you about that!!
    But then I like the mud like our friend Mr Whiskers here.
    The Bear Claw (or Mud Lite) rules that turf!!
    Doug
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
    May 2014
    Georgia
    168
    Awesome guys I appreciate all of the advice. Its nice being able to ask folks who have a ton of experience in the field already. When I have the money I'll replace all three tires but I'm gonna replace the back two for sure soon. Change of subject but do y'all have headlights and taillights on your rides? Mine is missing both and the mount for both is gone. I considered putting one of those led bars on the front because they are ridiculously bright. But Im not sure how I could mount it or the taillight?
    May 2014
    Georgia
    168
    IAlso, is there an aftermarket exhaust for the 250SX? And are there parts that fit the 250 and other three wheelers? Or do I have to get 250 specific parts?
    Jun 2014
    Southeast Missouri
    64
    Quote Originally Posted by dougspcs View Post
    Good luck..
    Do you know if that specific rim (or one with similar specs) is available in aluminum at Rocky Mountain ATV? I looked for one for the front of my SX in the past and couldn't find one that seemed to have the right spacing.
    3,415
    Quote Originally Posted by Marksman View Post
    Don't know..never looked. You'll have to do a search..
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
    3,415
    Quote Originally Posted by GSUwhiskers View Post
    Not sure what to tell you about the custom light thing..maybe someone else can.
    But the aftermarket exhaust can be a hassle..here is what I did.
    Buy this..http://www.ebay.com/itm/Kimpex-Exhau...a021ba&vxp=mtr
    Yes I know it says it's for the 250ES, but the length and curve of the pipe is the same..only difference is the location of the support bracket in the middle of the pipe.
    You'll just have to take a grinder and cut the bracket off the frame of your SX and it will bolt straight up.
    I put one on my 85 SX three years ago and it's still good!!
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
