Results 1 to 8 of 8
Thread: cleaning lower aluminum forks?
    dman10's Avatar
    dman10 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2013
    Elgin, TX
    402
    I have the front end on my '83 185s apart and figured I'd do some cleaning/touch up while I'm there.
    Anyways, I went to clean the aluminum lower forks, and used a Eagle 1 aluminum cleaner, but it didn't work?
    So, how do I go about cleaning them? making them shine?
    Quote Originally Posted by tri again View Post
    Cool stuff seems to happen when I'm sleeping.
    Nice to know things happen without me.
    N/A
    5,818
    different grade of steel wool. the works are clear coated from the factory.
    Jul 2013
    mo
    327
    Well u can try using liguid lightning drain opener to clean and eat the aluminum. Use rubber glooves and eye protection. Then i would use steel wool and mothers magnesium and aluminum polish and some elbow grease. I would do this to my rc cars all the time.
    http://www.youtube.com/user/effortequalsresults
    83 atc 110
    77 atc 90
    80 atc 110
    85 200x
    85 200x
    87 250es
    79 atc 110
    1978 atc90
    1985 200s
    1985 atc70
    1983 atc 70
    Oct 2006
    2,502
    Google or your search engine of choice has lots of information.
    https://www.google.com/search?q=how+...l=np&source=hp
    Jun 2009
    Leander TX
    2,217
    I either glass bead last them or hit them with a wire wheel in the end of my drill or angle grinder.
    For me, the glass bead gives them a dull finish and the wire wheel leaves a shinier finish.
    North Dakota
    1,643
    Ive had good luck with Marvel Mystery Oil oxidized aluminum parts with a little elbow grease and it seemed to clean it up but no where near new. Just makes it look better.
    emmie357's Avatar
    emmie357 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2013
    Upstate NY
    214
    As oldskool mentioned, they are clear coated from the factory. Over the years the clear yellows. That clear coat must be removed before the aluminum can be polished up nice.
    That's just like removing any other paint.
    84 YTM200E "yamahauler"
    85 YTM200
    85 KXT250 Tecate
    Mexico
    9,018
    Paint remover will take care of the factory clear-coat in most cases. After that your buffing will yield rewards. If you have some stains sand them with #2000 then polish. You can then leave it as a natural finish and re-polish it every once in a while or shoot it with a clear-coat spray bomb and it will last till it gets scratched off. When it gets scratched enough you can easily wipe it off with lacquer thinner and a rag and re shoot it.
