Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
Thread: atc 110 help
    6,798
    You have the correct 1981 motor .
    Lube up the cylinder studs , they get stuck at the alignment pins .
    Quote Originally Posted by elitespecialkid View Post
    Anyways, i got the piston freed (bike sat with open intake) but the cylinder wont come off, any ideas how to get it off? also, is there any numbers to identify the year of the engine? would like to get it sorted out.
    Cheyenne, WY
    89
    After a prybar, rubber mallet, and some cursing, i removed the cylinder, and upon inspection it needs bored. Does versah or similar company make a gasket/seal kit for these bikes? Whats available through honda? Should i go to wiseco for a piston? What is out there for aftermarket cams or big bore kits?
    6,798
    Not much out their as far as piston kits .
    Try dratv.com and eBay .
    If you want big bore high compression and other performance parts me .
    C.J is offline Just Too Addicted Arm chair racerJust too addicted
    Central, Louisiana
    639
    1981 is the first year for CDI , 1980 was the last year for points !
    My bad then,,, I try to remember too much stuff. Lol
    And DOHC you ARE correct on identifying the year of the ORIGINAL bike. However, when you are ordering engine parts (such as what the OP needs) you need to know the year of the ENGINE. Take my LT250R for example. Frame says H = 87 model. Cylinder is an 88+. 87 piston is different than 88 piston. Not supposed to run an 87 slug in an 88 jug but you can run the 88 slug in the 87 jug. SO if you went by the year on the FRAME it would be the wrong piston and you bust the sleeve. I know if different than the ATC110 but it's something you have to consider. I'm not saying you're wrong at all. Just sometimes you need to look at other things (like the engine) to know what year parts you need to buy for. In no way shape or form was I saying that you were wrong. Just that sometimes it's better to go by other means to see.
    Interested to see how you take that
    too many bikes to count. too little time on hand.
    Oct 2013
    Wherever I May Roam
    3,757
    managed to forget what year, any help finding a vin number or other identifying factor would be greatly appreciated.
    No problem, let's see here,
    Quote Originally Posted by C.J View Post
    Easiest way to tell is by if it's points or CDI or by the shape of the headlight
    Nope.
    CDI vs points ignition is the biggest thing cause it tells you what year the engine is
    hmmm, so if it has a CDI, what Year is it again? If it has points, what year....Remember now, we are looking for a specific year C.J., not a range. Stay focused now....
    Headlight Schmedlight.
    The easiest, ONLY, way to check the year on a honda 3 wheeler.
    Look at the neck. 10th digit is a letter. A= 1980, and so on.
    Hey, this guy knows what he's talking about.
    That's an 82+ engine and front end on an 81 frame if the vin says 81.
    Nope
    Tadaaaaaa. It's a CDI engine, has a different crank, cam, flywheel, ignition coil, clutch, and stator vs the 81-79.
    Tadaaaaaa, this is also incorrect information according to shortline10, and we are not looking for a range, we are looking for a year. Most people would not list year ranges backwards, just sayin.
    So, there ya go.
    Yep, there ya go.
    Don't rely solely on the VIN on the frame.
    Actually, if you want to know the year of the bike, rely soley on the V.I.N., because that is why they have one.
    So DOHC please don't think I'm just arguing with you to argue with you
    You are arguing with nobody. Just saying things, as far as I can tell.
    So to your last off base post I say the same thing.
    You are proving my point c.j.
    The V.I.N. is the ONLY true indicator of the year of the original bike.
    I said nothing about getting parts for things that have been changed on a bike over the years, you added that in yourself.
    The discussion was what is the year of the bike.
    Its an 81, you know how how I know for sure c.j.?????? Because that's what the V.I.N says it is.
    I'm not arguing. I'm telling.
    My 83 200x has a 2011 engine. What year is my bike? haha..
    I trust pretty much anything shortline says and he says 81 engines have a CDI. Looks like the V.I.N. matches the motor too........
    No Comment.
    Ya, I know.
    Ok so you are clearly out of your league here and scratching for a half a point. I get it. But no points for you.
    Sorry elite, It just had to be done. I'll behave after this.
    Central, Louisiana
    639
    I was wrong, I admitted I was wrong, and admitted AGAIN I was wrong. And who gives a flying hoot if the year range is backwards? It's not like it's 1981-2079. Mike never said that I was wrong about the differences between the years in the engine. He has told me that HIMSELF when I was buying parts FROM HIM for one of my builds.
    You've still yet to acknowledge the fact that I am right about going by the engine vin when ordering parts for the engine, which is what OP is asking. When an engine is seized, it needs: ENGINE PARTS!!!!!!!!!!!!!! So, go by the vin on the: ENGINE!!!!!!!!!
    Also:
    http://youtu.be/5hfYJsQAhl0
    This would have been a helluva lot better way to end your post!
    Shortline has spoken, OP has the info he needs, we are just being jackarses and dragging crap out. We are both stubborn it seems and neither will relent.
    Send me a PM and we will have the internet argument of the AGES!!!!!! Lmfao
    But anywhoot.
    Engine vin is best to go by when ordering ENGINE parts. If it were a 350SBC in a 36 Ford coupe, you wouldn't by ford parts for the 350 my friend.
    Oct 2013
    Wherever I May Roam
    3,757
    People pm me to try to prove their point all the time. Hasn't worked out in their favor so far. Be my guest.
    No need for me to relent, i'm not even acknowledging your information at this point because so far has been incorrect and/or irrelevant. Just responding to your posts, which will not continue. I don't want you to embarrass yourself any more. Have a good night.
    Jul 2015
    SW Oregon United States
    145
    Umm....I love debate. Anyhow I try to find stuff without starting a new thread so I got such a learning curve outta this one here's my post: Acquired a honda 110 today and negociating price (maybe $200) that has a frozen rear end. Don't know maybe rear end / tranny /frozen chain....don't care. I'll figure it out but trying to find out year, etc. and kinda looked for id on engine block to no avail. Front stamped frame is stamped TB0200BC212251 and head is stamped HM A4 and E2 6. Any help would help
    bump
